Removing head cover without removing engine???
  • mr_misfit138
    • Mar 2010
    • 54
    • Springville, UT
    I was going through a PDF copy of the XS1100E service manual, and I noticed that on two separate occasions it mentions that the cylinder hear cover can be removed without removing the engine. First, in the section for valve clearance adjustment, and then again in a note in the engine disassembly section that reads:
    "NOTE: Cylinder head and cylinder can be removed without removing engine."
    This is extremely intriguing to me, as it is something I would like to do, in order to custom paint the head with some high heat engine paint, but when I tried to remove it a few months ago without removing the engine, in order to seal up a leak in the gasket, I could only raise it up about 1/2" before it hit the frame (which was enough to RTV the leak), but there was no way to get it to clear the cam chain sprokets.
    Now, I don't have an E, I've got an SG, but I'm not sure if there's that big of a difference in the frames that would allow it on one and not the other.
    I've pretty much had to talk myself out of the painted head for now, because it's not something I want to pull the whole engine just to do, but if it was possible to pull just the head cover, I'd do it in a second. Is there something I'm missing? Is there anyone that's checked valve clearances on an '80 SG, with the engine still in the frame, that could give me any pointers?
    I'm looking forward to any help I can get.
    -Whatever it is, it's better in the wind.
    1980 XS1100SG - "Bluesy Suzy"
    -Oil cooler
    -TKAT Fork Brace
    -Drilled Airbox w/ K&N
    -Engine guards
    -Speed Bleeders
    -TC's blade fuse block (waiting to be installed)
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    I know it sounds silly, but go to the section that describes engine removal. There are a couple of things you need to remove from the upper frame so the valve cover will clear the frame. I'm fairly certain it's covered in the engine removal section. IIRC, the horn bracket and the ballast resistor are in the way.
      You did remove the fuel tank, right?...
      That's the only thing that could prevent you from getting the cam cover out that I can think of. There's all kinds of room, unless your bike has been modified somehow...
      • mr_misfit138
        • Mar 2010
        • 54
        • Springville, UT
        I did remove the horn bracket, but I definitely didn't remove the ballast resistor. I would like to say with confidence that I had the tank off, because at the time I did it, I was constantly working on carbs and fuel lines, so the tank usually resided elsewhere. I'll have to take a closer look next time I dig into it and make sure that frame hasn't been modified. I've noticed that there are a lot of things that the PO had done, but I hope that the frame wasn't on his list. It definitely doesn't have any major changes to it, so I doubt he altered it. I probably just had a brain fart and had left overlooked something simple.
        -Oil cooler
        -TKAT Fork Brace
        -Engine guards
        -Speed Bleeders
          I pulled the head and the jugs off with the engine in the frame. nothing to it.
            • 9980
            What was the cover hitting that it couldn't be raised mor than 1/2"? I've had several off with the engine in the frame.
              • 5062
              It is like a chinese puzzel. It will clear.
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                Sometimes the balast resister mount welded to the frame has been bent down to make it easier it install and remove the resister (PO). You may want to bend it back up to avoid a scratch when jiggling the valve cover off. If the cover screws are left in the cover even loose they hang so take them out. Others may have replaced the coils and made special mounts that interfeer but they should be able to be removed. If those do not give room send a picture I am sure someone here can help.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                Barnett Clutch Springs
                R1 Clutch Fiber Plates
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                  If that's an otherise good runnin motor, removin' head/cyls. to just paint???......and not soundin' really confident/mechanically inclined.........might wanna re-think your choices IMO....
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    I've had the cover off my SG a few times now. I've found that removing the ballast resistor is key.
                    That gives me more room to get the cover out and over the cam sprokets.
                    I also pull the plug wires up thru the frame to get them out of the way too.
                    I've had to move the cover forward and back to get the right spot to clear the cam sproket.
                    Just don't get fustrated and it'll come out. I think it's easier if it goes to the left side as it comes out.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                    • James England
                      • 3039
                      • North of England
                      I've had several off. It's like a Chinese puzzle... you know, one of those things that are two bits of bended wire. You jiggle and twist and eventually they part and you don't know how you did it. That's that I found the camcover to be like. There's a definite twist and tilt and move forward/backward involved....
