fuse block
  • bcknblkbird
    • Mar 2009
    • 124
    • jonesville nc
    fuse block
    been searching for fuse block wiring diagrams with no luck. so what wire goes where? i understand blue to blue. what about the brown wires. what size fuses go where? i have a wiring diagram but i'v got the iq of a eggplant when it comes to such things. btw thanks again TC !
    • 9980
    There is a link to online manuals from cbugs signature.......
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Dont know if this helps? On my 79SF the size of wire was a tell tell and there was a 30amp, 20amp and two 10amp fuse's that went with the different size wires
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        ...i understand blue to blue. what about the brown wires. what size fuses go where?
        The blue is your tail/running lights (10A), the big brown connects to the other big brown which is the turns, horn, etc (20A), the two smaller browns connect to the red/yellow (headlight, 10A) and red/white (ignition, 10A)....
        • bcknblkbird
          • Mar 2009
          • 124
          • jonesville nc
          does it matter which of the smaller browns connect to red white or red yellow?
            No it doesn't, they are split taps off of the main power line/harness, so there's no worries about mixing them up, both browns are just power(+12V) and you're just putting a fuse between it and the two circuits they power, the red/white and yellow/white. As Steve said the larger wire is required for the turns because they draw more power/amperage.
            The MAIN fuse is in a separate holder on the other side of the bike.
              • 5051
              (snip)
              Well, I suppose that depends on the year/model. The model 78E is fused in the fuse block.
                • 7785
                I organized my wiring by the length of wire I had to work with. My daughter printed me a very nice label.
                • bcknblkbird
                  • Mar 2009
                  • 124
                  • jonesville nc
                  thanks to all who replied, with all this info i can't go wrong! (i hope) lol!
                    • 5051
                    Nice, neat job Marty.
                      Hey Skids, Yes I know that, but I was specifically stating it for his XJ.
                      • barrelguy
                        • 169
                        • Oliver, BC
                        Fuse Block / Main Fuse
                        I just installed a fuse block in my 80 SG (Lordco Auto Parts $13.00). PO had changed to flat fuses but had just left the holders dangling in the breeze. I was going to move my main fuse over from the left side to the block and noticed it was a 20 amp. Nothing seems to have been harmed by this but shouldn't it be a 30 amp?
                        1980 XS 1100 Special
                        Mostly stock & original
                        Added Yamaha fairing (w/ 8-track!)
                        Torpedo bags
                        New paint (still) pending
                        Stainless brake lines
                        Tkat forkbrace
                        Coils from Honda 1000
                        Previous bikes:
                        1968(?) 350 Harley Davidson
                        1977 Yamaha 650
                          Yes, it should be a 30. But truthfully, on a naked bike (no extra lights, fairing, etc) a 20 amp fuse can work but it's probably operating near it's limit. So put in a 30 anyway, it may save some head-scratching on the side of the road...
                          • ScottBJ79
                            • Apr 2013
                            • 14
                            • Bremerton, Wash. (soon to be Hawaii)
                            Fuse block
                            I am getting ready to change out my OEM block with one I just revived from TC, one of the previous owners made some mods to the box already, I'm not totally sure which fuse is which at this point, the attached pic shows where it sits right now, none of the glass fuses have a legible rating on them and the blade fuse is a 25amp, a little assistance would be appreciated.
                            79 XS11F.
                            “Sometimes, for some people, things don’t work out as they might have hoped. Hope is a strange thing, a currency for people who know they’re losing. The more familiar you are with hope, the less beautiful it becomes.”
                              • 8672
                              Main 30A (red wires)
                              Turn sig 20A (fat brown wire)
                              Ign 10A (thin brown wire)
                              Headlight 10A (thin brown wire)
