Oil Filter Bolt
Many techniques have been discussed on here...hint, hint, search "remove filter bolt".
If access to welder, weld large hex nut onto end of bolt.
Gator Grip socket.
Flat file to reflatten edges a bit, then get a slightly smaller 6 point socket to hammer onto end of bolt.
Apply Penetrating oil, also torch or safer heat gun application for a few cycles of heat/cool down to help break corrosion/adhesion.
File flat or dremel cut/flat 2 opposing surfaces of bolt so be able to better afix aforementioned vicegrips....or pipe wrench, or crescent wrench.
Buy new bolt from local dealer, www.partsnmore.com, etc., and then just Dremel cut the head off of bolt..had large washer head, then slide filter cup down off bolt, then you can grap remaining bolt to loosen remove from engine, then put in/on new bolt!
Gator Grip socket.
the XS1100 clutch is tough, so use the right oil, adjust (at the clutch, then at the handlebar), and could still be fine, if not, new springs should fix it
Now, the bolt on the oil filter, it is trashed, so BikerPhill's idea of chisel and brake it loose should work, even if you have to trash the filter case, you can get one on Ebay cheap
