turn signal parts question
  • silver_ride
    • Aug 2011
    • 41
    • Minneapolis, MN
    yeah those mounts are going to be a headache, thanks for the pics it helps a lot...if i cant find any its going to end up being some kind of hose-clamp and zip-tie monstrosity, and thats not the look i'm going for. but again if anyone has any past experience rigging this stuff up to look somewhat clean i'd love to hear what you did
    80 XS1100G
      Or make up a L bracket to bolt onto the lower trees and then bolt the light to the bracket.
      Hose clamps and zip ties look bad.
        Are these what you need?
        Turn Signal Brackets Stainless Steel XS650
        I'm going home tomorrow and I can check if the XS650 tree has the same bolt spacing as the XS11.
          Those might work on the Special lower tree (where the pinch bolts face to the side), but not the standard; they face foward....
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            I found one (right I think) on ebay.
            http://www.ebay.com/itm/Yamaha-NOS-C...item2a17c515a5
            It's a little pricey, but it looks to be in mint condition.
            the part numbers are 2h7-23132-00-00 and 23122 (right/left)
            I hope that helps a little. The bracket idea seems like it might work. Bolt them right to the lower tree and then use any XS light.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • jwhughes3
              • 2798
              • Home of the Alamo
              Marty did you check?
              Inquiring minds want to know!
              John
              '81 XS1100H - "Enterprise"
                I believe these don't work. The bolts on the lower tree on the XS650 are perpendicular to the wheel. I don't believe that is so on the XS11.
                  I just had a look and took a scale with me. Those Motolanna brackets will work on the Special. Best I can tell the bolt spacing on the lower tree is the same on the XS11 and the XS650. Bolts are perpendicular to the tire on both bikes.
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    Thanks Marty!
                    Good info.
                    I like that site! That aluminum swingarm looks sweet.
                    John
