View Post
Need help with wiring. So lost
Good picture CY. Glad to see you are doing better. I would have done it but I am 100 miles from home tonight.
Now with the picture and the info Steve sent you should be able to solder and test. You still may want to clean and lubricate the switch internally after the fix.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
Not to hijack but looking at my switch it appears that I've been POed. My brown/white wire appears to be in the wrong spot.
Would this cause a very rapid blink when the hazards are on but let the blinkers flash at a normal rate?Last edited by daf1668; 01-28-2012, 09:41 PM.Current 1981 xs1100H
First Bike was 1982 xj550j
my switch solder repair
I had to resolder my switch leads back together a few months ago. My advice is to watch how hot you get the joint. I had a hard time getting mine to stay connected after it cooled. So I went and got a soldering gun. (More heat) it so hot, the plastic started melting. After about 2hrs I finally got it all back together.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride
IIRC that is the same place electrically, so it should work fine. The fast on the 4 ways but normal on the normal turn signals would point to the wrong flasher unit on the 4 way flasher. Easiest fix is to replace the 4 way flasher with a 2 prong heavy duty automotive flasher which will then always flash at the same (proper) speed no matter what the load. I'm seriously considering changing mine out that way to get more noticeable 4 ways, as I'm not happy with the way they work right now. I've got one laying around that should work fine, I just have to do it, but I'm running a little short on get up and go for some reason right now. I can't figure out why that would be though
Other than installing the replacement mirror when it comes in, and tightening the highway pegs some more, I've pretty much got the mechanical work done (still got one or two things left to do, but the bike is street worthy as of this moment), but I can't seem to make myself get down there and do the work to put the auto cam chain tensioner in.Cy
Originally posted by daf1668 View PostNot to hijack but looking at my switch it appears that I've been POed. My brown/white wire appears to be in the wrong spot.
[IMG][/IMG]
It's right under the seat where you sit.Greg
Turn and Hazard Schematic
Mr. T, I honestly don't remember where the wires connect on the switch and I'd have to open it up to take a picture; not going to happen today.
Here's the Yamaha factory schematic for the turn signals and hazard flashers.
Click the image to enlarge:-
I re-soldered all of the connections a few years ago and I know they work because I keep testing them by bumping the switch with the back of my hand when I unsnap the tonneau cover on the fairing.-- Scott
