Wow!!!
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Wow!!!
    WOW!!! is all I got to say. As some may know I have rebuilt my carbs 5 time and tuned and tuned and tuned Still had poping through exaust, better, but still there So, I replaced the OEM fuse box and removed 10 PO splices, went for my 1st test ride today, WOW, all this time the gremlins I "thought" were in the carbs, were in the elec system Absoluty NO poping, "0" Nadaa Runs like a new bike No drop in idle speed at long lights No sputter at take off To anyone with the OEM fuseBox GET RID OF IT!!!
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    Glad to hear it's performing good for you!......Rule of thumb is diagnosing electrical, primary or secondary ignition BEFORE condemming fuel system. Kinda old school, but so are these scoots and applies in the pre mid eighties automotive world also.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      Thanks
      Who-da thought, wireing that is only 32 years old and was the weakest link when it was new and had been "FIXED" by the PO Don't know why I didn't fix it the 3rd time I blamed the carbs Oh well, I am a pro at R/I carbs now
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        • 8919
        Nice, now your spark plugs probably won't foul anymore since the coils are now getting their proper voltage.
          I have learned that this is the first thing I do to any XS11 I work on. In the time I have been reading this board, I have seen A BUNCH of what was believed to be fuel and or coil problems fixed by replacing the fuse block, followed closely, if not tied with, repairing the pick-up coil wires.
          • ddragon63
            • Jan 2012
            • 1101
            • Ridgefield, WA
            See... I don't have any of those problems. But now I think I have to get a new fuse block. Everyones doing it.....
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
            2005 V-Star 1100 Classic
            • dpotter58
              • Aug 2004
              • 1865
              • Southern Maryland
              I fought "carb &backfire issues" for a year. Turned out to be the pick up wire problem.
              1980 LG
              1981 LH
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Well golly
                Well like Gomer Pyle said Golly " I have seen A BUNCH of what was believed to be fuel and or coil problems fixed by replacing the fuse block, followed closely, if not tied with, repairing the pick-up coil wires" Gee, Sgt. Carter's Golly, I am just a Gomer trying to help Golly, you fellers are smart
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • ViperRon
                  • Feb 2011
                  • 1062
                  • Woodstock, VA
                  happpy for you and me
                  I am happy you finally fixed it and so happy I am an original owner. No Splices no dices no bent carb parts. At least when I deal with a problem its not a barn yard modification. Still I am glad for you.
                  Rodan
                  1980 G Silverbird
                  1198 Overbore kit
                  Grizzly 660 ACCT
                  Barnett Clutch Springs
                  R1 Clutch Fiber Plates
                  122.5 Main Jets
                  ACCT Mod
                  Mac 4-2 Flare Tips
                  Antivibe Bar ends
                  Rear trunk add-on
                  • mharrington
                    • 407
                    • Holland MI
                    !!!!!!!!!!!!!!!!!!!!! I was really feeling bad for you not finding the problem.. You sound like you are officially a carb expert now though. Good job!
                    • Rooster
                      • Oct 2009
                      • 84
                      • Lacombe, Alberta, Canada
                      wiring
                      Yeah I found that my main ground wire from battery to frame was nearly broken completely loose so it may explain my power issues. And likely it would cause the low power to coil problem as a bad ground is almost worse than anything else cause if the positive wont get through it's an easier track to follow but a bad common ground loop can cause issues anywhere.
                      Even a blind monkey gets the odd banana.
                      1979 XS 1100 special (been down the PO trail and it was messy)
                      • tom clisham
                        • Sep 2010
                        • 627
                        • Northern Illinois
                        Carbs
                        Now that you're a carb expert, I've got a couple sets to send , to keep you in practice!
                        Tom Clisham
                        79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                        • je2wheeler
                          • Feb 2010
                          • 180
                          • Moved to NC to help my Dad
                          Carbs
                          Great to have all that weight off your back, I also know what it feels like. My father, years ago, said that 99% of carb problems can be found in the ignition. Sometimes my brain over rides this wisdom and I too have chased those elusive gremlins about only to drive my palm into my forehead, again. Ride and enjoy the freedom!
                          1979 XS 1100 Special - Nicknamed "MONSTER"
                          ATC fuse box
                          Braded stainless brake lines
                          4/2 aftermarket exhaust(temp until stock is re-chromed )
                          V-Max auto cam chain adjuster
                          Brake light modulator with reserve brake light bypass
                          Vetter Windjammer III faring
                          Tkat Fork Brace
                          "Americans have the right and advantage of being armed; unlike the citizens of the countries whose governments are afraid to trust the people with arms”
                          James Madison, The Federalists Papers
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Thanks
                            Thanks, I feel kinda stupid for not doing it 4 carb rebuilds ago. 10 bucks! and worth a thousand!
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              10 bucks!
                              hey Dragon, its 10 bucks, the best 10 bucks I have ever spent I know your bike runs good and you know the history, but these fuse boxes were just OK when new, and everything wears out, trust me on this one and I will bet you will notice "Some" improvements
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
