side cover repairs
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    side cover repairs
    Finally getting around to doing a resto thread on my side covers, I'm concentrating on repairing and restoring those pesky broken and seemingly expensive to replace side covers, these may not be XS1100's(GS1100) but they were in worse condition than the Specials so I thought these would be more suitable due to their deplorable condition. I already started the rough sanding on the first one and popped the broken plastic back in place(always tough without breaking completely) And will grind a grove in and along the crack with my dremel but not all the way through, then proceed to fill it in with the putty, and sand after it cures, followed by very fine sanding. Then I will proceed preparing it with sand-able primer. The second one has actual pieces missing, this will be fun...no really, I'm actually pretty good at making something from nothing, especially when you have nothing, you get good at it. stop here for pics and further progress.
    Will also be using some superglue, cardboard for mold backing, gotta wait for that pesky dremel to charge...zzzzzzz
    81 XS1100H
    The one thing I would suggest is to 'overlap' the repairs on the back side by at least a 1/2" all around for strength (about 1/8" thick). When I fixed a pair, I had trouble with them re-breaking when flexed until I did that.
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      Yeah, I had planned on something for backing support, but haven't decided on what yet, I have some very thin sheetmetal I may cut and epoxy in place, still thinking on what I want to use.
      81 XS1100H
        I don't think you need to use any 'other' material, just spread your repair goo out more on the backside. I used the superglue/baking soda mix, and my cracks kept opening up until I 'coated' the whole area around the fix. That did the job...
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          Fiberglass
          I would cut a backing patch about 1/2" + bigger then the hole / crack, to use as a backing. The type that looks like a bunch of fibers, not the kind that looks like cloth. Sand the contact area with 80grit, saturate the cloth with resin mixed with hardner then attach and let cure, finish the front with the fillet, JIMHO
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • old_skool
            • Nov 2011
            • 554
            • Ohio
            not using any fiberglass
            81 XS1100H
              • 2104
              Jat...
              "Then I will proceed preparing it with sand-able primer."
              Krylon® has a robust product mix for you to choose from for your next project. Learn more about the full line-up of products today!
              Hey Old School, the above link is what I used on my XJ750 Mid Max plastic air filter trim. Painted them 2 years ago and they seem to be holding up fine. Krylon Fusion needs no primer and bonds really well. For a smooth finish, paint a coat, let cure, sand with 600 wet or dry and repeat until You're satisfied, as it seems to be a high build product that will sand very well.
              Heres a pic of my XJ:
              I painted them and slapped them on, but they could use fine sanded with 1000 wet or dry and polished then waxed but I'll get to that when the Eleven is on the road and I can take the XJ apart for a full resto.
              • ddragon63
                • Jan 2012
                • 1101
                • Ridgefield, WA
                Drill a small hole @ the stopping point of the crack to stop its run. They make a plastic body filler (auto usage) that is very flexible you could try. Back it with something fill the area and sand it down. JAT
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                2005 V-Star 1100 Classic
                • psycoreefer
                  • Feb 2008
                  • 1557
                  • Minden, NV
                  I put a single layer of thin fiberglass with some epoxy resin on the back of my 'cracked' side cover and I've been using it daily for 2 years now and its still holding on nice and strong. Once the fiberglass was dry I used a soldering iron to melt the crack back together and then filled with several layers of filler primer. I can take some pictures when I get home....
                  1979 xs1100 Special -
                  My Bike:
                  [link is broken]
