Elec Guru's / CS?
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Elec Guru's / CS?
    OK, it was just getting dark and I started my bike as maintance. After I warmed it up, I let it run at 3000rpm for 40sec or so. Ran OK, but sputtered just a little, I noticed the nutral light would dim just a little when it sputtered, then would brighten and sputtered stop, them back to sputter and dim, no rpm drop
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    If only the neutral light was doing anything weird, then look at it's connection to make sure it's tight. It might also just be the vibration caused the switch to 'flutter'. Either way, shouldn't be a big deal...
      You need to actually ride it, not just start it. No wonder you are having problems.
        • 3193
        Or as is the case in our northern climate. Charge the battery regularily as part of the maintenance. Then if there is issues that present, you are at least not chasing a half assed charged battery issue. Not saying that is your problem, but if it has not run in a while it may be worth doing.
        • ViperRon
          • Feb 2011
          • 1062
          • Woodstock, VA
          Sounds like a connection problem that fixed itself. These bikes are trainable. If you let them sit there idling looking for somthing to work on long enough they will break for you.
          Rodan
          1980 G Silverbird
          1198 Overbore kit
          Grizzly 660 ACCT
          Barnett Clutch Springs
          R1 Clutch Fiber Plates
          122.5 Main Jets
          ACCT Mod
          Mac 4-2 Flare Tips
          Antivibe Bar ends
          Rear trunk add-on
            The neutral indicator wire and the pickup coil wires are in the same wireloom under the left lower frame rail. If the wire insulation is deteriorated to the point the wires can touch the pickup wires will ground through the neutral indicator wire and switch causing a stumble and the light to flicker. It will be more prevalant if the wires are wet.
