I rounded up a pair of side covers and want to slick them, ie remove the emblems. The originals are perfect and will go in storage so I can go back to the stock look later. Question is what to use to fill the holes, any suggestions?
Side Cover Holes
Side Cover Holes
wingnut
81 SH (Daily Ride)
81 XS 400
Thomas JeffersonTags: None -
Super glue and baking soda... seriously. This sticks really well to the plastic, and can be sanded/painted. Put a piece of tape over the holes from the outside, squirt some glue in the hole, then dust some baking soda over the glue. It'll take multiple applications to build up enough thickness, but it sets up almost instantly so won't take much time at all. You might have to dust a bit on from the outside after removing the tape, then sand it flat.
Works great....
Yep, can't leave nuthin' alone... -
Super Glue
Permatex makes a few varieties of super glue and some hardware stores can hook you up. What you want is "gap filling" super glue. The Permatex brand will be labeled as such. You can apply it as Steve suggested.
If you use Bondo or other such body filler be sure to cover it with paint on both sides. It shouldn't be left exposed to the air.Marty (in Mississippi)
XS650EComment
I have a couple cracked side covers and some with the holding tabs busted, I'm going to try this stuff called qwik putty, you can get it from harbor freight, mold it, press it in place , dries hard, sandable and paintable, permanent. Oh yeah....cheap81 XS1100HComment
I have repaired lock tabs, cracks,and even a hole that used to be there for a lighter in my side covers with the super glue and baking soda trick. It is fast easy cheap and great. You can even take the part to the bench grinder and use that to shape it after, that is how tough the stuff is. Why mess with success
2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
Thanks Guys super glue it will be.wingnut
81 SH (Daily Ride)
81 XS 400
Thomas JeffersonComment
For small holes, if I didn't already have the putty, I might go that route, but with larger holes, cracks or missing pieces, its just easier to roll out some, pack it in place and wait to cure, less mess and ingredients. but thats definitely a easy fix, especially if you have the glue on hand, don't have to go to the store.81 XS1100HComment
The other thing is that if the putty works good then it is another weapon in our arsenal against tossing valuable parts. Go for it and let us know how well it turns out. Maybe take a few pics if you can, cause we all love to see how stuff works.
2-79 XS1100 SF
Thats a good idea, I'm bumming out thanks to the snow, but I can do some of that if not all the repair in the house without SWMBO getting too upset. I'll take a lot of befores (these are almost throw aways) and see if I can resurect them.
Hope you don't mind, I'm going to repair the GS1100's first as they are in worst shape. The Specials' have broken tabs, so I'll do a different follow up, write up on them. Plus I'm at a holt on my carb re-assembly as I have to deal with the diaphram pinholes and lost a crush washer that goes to the drain plug on the bowl on one.Last edited by old_skool; 01-15-2012, 11:53 AM.81 XS1100HComment
Repair
Everything you need to do it right and for good in one kit, including backing cloth and sand paper for 15 bucks
http://www.acehardware.com/product/i...ductId=1383221
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
Sounds silly but I just put a couple of short, stainless, Allen head bolts into the holes. You'd be surprised how many times someone will ask me what I've done to "trick out" my side covers. I kind of like the looks as well.
Just another thought.1995 KZ100P
Pods, jets, pipes, cam adjuster, oil cooler
1977 Ironhead - custom build
Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.Comment
lets see some pics81 XS1100HComment
