How to diaphragm &$$$
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    I found this, it shows how to replace the diaphragms on our bikes, it is also the cheapest I have found replacements, 60 bucks for 4
    http://www.ebay.com/itm/BRAND-NEW-4p...sories&vxp=mtr
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
  • mharrington
    • 407
    • Holland MI
    Thats a good deal. I saved this to my favorites months ago:
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      OEM style
      That is a different style diaphragm that has a built in retainer ring. DO NOT cut the OEM retainer ring like that if you dont have that style of replacement If you do, you will need a whole new diaphragm assembly part$$$
      http://jbmindustries.com/Yamaha650.html
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • mharrington
        • 407
        • Holland MI
        I assumed they were the same. Actually its nice we have more than one affordable option.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          diff.
          In this pic, you will note that the inside hole has a small thin ring. Do not cut the plastic retainer on this type
          In this pic you will see a thick retainer ring built into the diaphragm. Platic retainer must be removed on this type, making it so you can't us the OEM type again
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            Thank! You!
            I've been wondering about the difference between the two types of replacements and you've just made it so perfectly clear that even I can't forg...
            Ooh! Shiny!
            • petejw
              • 2269
              • sydney australia
              ive replaced my diaphrams with the top ones in the pic
              and have cut the top plastic retaining clip to fit them
              without any problems what so ever, theres a write up on
              here some where, if ur interested i can find it.
              btw $60 for 4 of them is really good value.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Mfg
                Thats cool. I tend to go by the MFG's instructions when installing their stuff I know guys that do stuff their own way and get away with it. There is a guy on here that adjusts his valves by jamming zip ties between the valves and seats to hold them open, hay, if it works, its your bike, enjoy
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • James England
                  • 3039
                  • North of England
                  Personally, I'd be reticent to cut anything off the OEM slide. When I replaced my diaphragms, I used the type with the thin ring. They go on easily if you use lighter fuel (liquid type) as a lubricant...
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    +1 once you remove it, you cant put it back like it was, and the whole sliders are $$$. But, having seen what some PO's have done and still got them running, or at least enough to sell it to some poor smuck Like I say, it their bike, do as you will
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
