The reply I got from one ebay seller is he applied it to a stick, then soaked in gasoline overnite, with no affects, that was the liquid tape by plasti dip, he was willing to experiment for me, so I'll do the same.
diaphragm
I have used Ultra Black RTV and it is flexible, and stuck well (after cleaning the diaphragm). Been working for a long time.Skids (Sid Hansen)
Liquid tape worked fine on mine for two years now. You have to put it on the top side of the diaphragms only. There is no fuel...only air gets there...YMMV2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Finger
Originally posted by skids View PostI think I did use my finger.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
ok, went the liquid tape route, all pinholes gone, will have to see how they work, will prob take pics of finished carb in a few days, and its supposed to warm up in the 40's again in a few days, so may get them installed and tested, think I'm going to double down and do the same to the fuel intaks, they have more than micro cracks...81 XS1100H
Originally posted by old_skool View Postok, went the liquid tape route, all pinholes gone, will have to see how they work, will prob take pics of finished carb in a few days, and its supposed to warm up in the 40's again in a few days, so may get them installed and tested, think I'm going to double down and do the same to the fuel intaks, they have more than micro cracks...
Personally, I would fix your diaphragms properly. I would think a coating, however thin, will affect the elasticity of the diaphragms and, if you bit he financial bullet and fix it properly, you'll be better off in the long runXS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Right now its a financial machine gun, not a single bullet...but if I have to tear them down again, I guess I won't have been the first XS-er to have to pull the carbs again and again and....but seriously, they're already dry, no light showing through, and believe it or not, just as pliable...hmmmmm, now if the fuel/fumes don't affect them.81 XS1100H
Aside from dissolving patches, another problem I ran into was that even after a light coat of plastic the diaphragms were a little too stiff and that kicked up the fuel consumption.
I had to carefully spot-treat and patch only the holes and the slides still didn't really move the way they should. The patches worked for a short-term fix but in the long run it didn't take very many gallons of wasted $3 or $4 gas to exceed the cost of a new set of diaphragms.-- Scott
Originally posted by 3Phase View PostAside from dissolving patches, another problem I ran into was that even after a light coat of plastic the diaphragms were a little too stiff and that kicked up the fuel consumption.
I had to carefully spot-treat and patch only the holes and the slides still didn't really move the way they should. The patches worked for a short-term fix but in the long run it didn't take very many gallons of wasted $3 or $4 gas to exceed the cost of a new set of diaphragms.81 XS1100H
Not trying to talk you out of it, just giving you a heads-up in case the diaphragms are hardened or rotted.
I was in almost exactly that same situation you're in when I dug into the carburetors on Columbo. The patches worked okay at first but the bike had sat for too many years so the rubber was going bad.
When the slides moved the rubber tried to roll with them but it would split next to a patch. Gas and fumes would go through the new holes to the top of the diaphragm and melt the patch so I'd have to make a bigger patch; then a bigger patch to patch the patched patch; then... well, you get the idea. After a few months and a few thousand miles even the 'good' diaphragms that didn't have holes or patches in them started to leak and they had to be fixed, too.-- Scott
Diaphrams
One thing to keep in mind is that what ever approach you take to repair the diaphrams it is only a temporary fix. If small holes have developed its an indication the rubber is breaking down for a reason. Its possible some PO cleaned them with something that is now breaking down the rubber. You can buy the best solution to repair and in a little while have a new hole to repair. If I had little money to spend I'd do a proper prep and temporarily repair with the dip as it will coat the entire surface hense giving you the best chance for current and developing holes being sealed. Understand in the long term you need a plan to replace them.
With the intakes make sure you use a high temp rubber or silicone sealant as the regular rubber sealants will crack and come appart quickly. Make sure to allow the sealant to cure fully before you run the bike as there is more movement than you think.
Good luck RonTo fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
