finding parts
  • devildork
    • 20
    • seattle, wa
    finding parts
    i might finally be able to get back into this after a ****ty year. so i am on the hunt for parts now. the main ones i am looking for is the electrical. i do not trust the harnass and came with the bike and am just going to start over. where is the best place to go? also i need a seat. i do not care if it is ripped or anything as i am going to most likely recover it. any suggestions for the seattle area ? or on-line ?
    81 XS 1100 H
    Hey DD,
    First thing you need to do to help us is specify which model you have, and if your looking for stock or if your modding the bike. Each year and model had some changes to it, some of which changed the wiring harness. The seat is one of the least interchangable parts, so it is critical to ensure your getting the pan for the year and model of your bike.
    For future post, it can be very helpful to dit your signature line to include the model and year of your XS1100, then folks won't have to ask when it is important.
    • devildork
      • 20
      • seattle, wa
      ooooops
      i am sorry i ment to type that in but i forgot i have an 81 XS1100H that came to be as a basket case and sat behind a guys garage since '93.
      81 XS 1100 H
        ok well in that case, I have a wiring harness from an SH, which should be relatively if not completely the same. Never owned a Standard so I am not certain of it. The primary things I can think of being different are the turns signals if they are still running lights int hat year, but I think there is a wire on the harness to feed those.
        As to the seat, I believe the Venturer (an 81 H model) is a one off.
        • devildork
          • 20
          • seattle, wa
          how much would the wiring harnass run?
          well that is not a good thing on the seat. hopefully i can find one if not i guess will have to fab something up. thanks for the info.
          81 XS 1100 H
            One thing you need to verify is if all of the bike is a '81 (seeing how basket cases can sometimes be a 'mix' of 'stuff' ). Specifically, if you have a '81 ignition setup on the motor as that's a one-year-only piece with little interchange of parts.
            As far as a wiring harness, unless yours is really hacked up, you'll be just as well off to repair yours or replace with a decent used one. Building one from scratch will cost a small fortune...
            If you're willing to make a 2-hour drive south to Yelm with your harness, I'd be happy to help you check it and maybe even repair any problems. I'll send you a PM with contact info...
            • devildork
              • 20
              • seattle, wa
              well i was TOLD that it was all the same year. i guess i am nto 100% sure. the story is that friend of mines ex father in law bought it years ago but dropped in in '93. got parts to put it back together and never did. freind thought would be fun to play with took it all apart got bored and gave it to me to actually to scrap. i just could not scrap it so now it is my turn to play.
              I will look at see how bad really the harnass is.
              where does one check that the engine truly is an '81?
              81 XS 1100 H
              • latexeses
                • Jun 2008
                • 1491
                • California
                Serial number should start---4R1-
                Canadian ----4T1-
                Right side of the engine crank case. Right there close to the oil fill.
                Everything on hold...
                • devildork
                  • 20
                  • seattle, wa
                  there is a 4R1, guess that means it is the 81 engine. cool thanks.
                  81 XS 1100 H
                  • Cobia
                    • Jul 2007
                    • 1587
                    • Palm Beach County, Fl
                    Hey DD,
                    Welcome to the forum.
                    As far as getting the best deal on parts, and you being in WA, I have two golden words for you....... Andreas Weis. He's in WA and the best person I've found to deal with for replacement parts.
                    Look him up in the parts for sale section.
                    Good luck.
                    1980G Standard, Restored
                    Kerker 4 - 1
                    850 Rear End Mod
                    Automatic CCT
                    1980GH Special, Restored
                    '82 XJ1100 (Sold)
