Battery
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Battery
    Ok, I needed a new battery, didn't have or want to spent anouther 100 bucks for a super man battery, so I bought the Walmart special for 48 bucks. I slow charged it and did exactly as the booklet said. When i put it in I had just done some carb work and stuff, so I cranked it alot to get it going and sync'ed. Once all up and running right i put it on a the trickel and brought it back to full charge. Now, a month or so later, it cranks and starts right up, but when I stop at a light sometimes the turn lights stop blinking less i rev the motor and it will pop some and start off sputtering, then smoth right out when the rpm's get up, and the tac jumps around now at low rpm Sond like a new battery to replace my new battery I had also replaced the hearligh bulb with a 60-55w rating on the box, but was told the same as the 55-60w OEM buld Any other thoughts
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    Easy......take the seat off put a volt meter on battery at idle, see what you got. If ALL primary circuit connection are KNOWN good, should be a a few tenths above 12V.............run it up to a steady 2500rpm.........should be in the neighborhood of 14.5V.
      Sounds like you've got some bad connections. I wouldn't blame the battery. Check all the electrical connections, especially the grounds. Disconnect them, clean the corrosion off (even the stuff you can't see) and treat them with dielectric grease. The main frame/engine grounds can be treated with anti-sieze instead, since it helps with conductivity, and there are no other connections nearby to worry about.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Cool
        I will clean them all JIC, I still have the OEM fuse box, so, goina replace that as well before I buy anouther battery, the volts at the batt looked fine so I was looking for someting that is causing the strange running, dot know if the 60-55w headlight could be part of the prob, but I only run on dim, so I don't think so Gremlins
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          OEM fuse box
          I forgot who sells the replacement fuse box for the OEM POS
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • Danny Crawdad
            • May 2011
            • 239
            • Birmingham, Alabama
            TopCat! Geezer sells one too.
            I had the same problem with mine (blinkers would stop blinking at idle), and replacing the fuse box fixed it 100%. Easily the best mod I ever made.
            XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
            Well, goodness. Look what we've got here.
            • old_skool
              • Nov 2011
              • 554
              • Ohio
              I picked up a 6 place at Autozone for 8 or 9 bucks, plus they sell the flag connectors also.
              81 XS1100H
              • GLoweVA
                • Jun 2011
                • 1957
                • Virginia Beach, VA.
                TC's fuse block
                Here's his complete handle: TopCatGr58
                Here's a pic of one installed in my 80SG:
                I got 2 from him $10, but that was no shipping, Local pickup.
                The block has the 90deg connectors with it and a it's a 6 circuit block, so it has a spare one for any extras you might want to wire up.
                80G (Green paint(PO idea))
                The Green Monster
                Got him in '04.
                bald tire & borrowing parts
                Scarlet
                Got her in '11
                Ready for the twisties!
                81H (previously CPMaynard's)
                Hugo
                Cold weather ride
                • JasonRedbeard
                  • 109
                  • Tuscaloosa, AL
                  I snagged the same fuse box off Amazon, and the 90* terminals from Advance. $15 total investment....installing this weekend.
                  My Special is as old as I am.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    6 fuse holder
                    I have seen most of these have 6 fuses and also that most guys leave the glass fuse thats outside the OEM box alone Any reason not to hook it up inside the new box?
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      The blinker might just be your idling to low, same with the sputter. You should have your Idle set between 11 and 13 hundred to get stuff to work right.
                      Mine is set at about 1200 and works great.
                      Of course I DID have an off idle sputter when I had used aftermarket carb kits too. The pilot jets were jacked and caused a sputter on accelleration.
                      • ddragon63
                        • Jan 2012
                        • 1101
                        • Ridgefield, WA
                        other than your hi watt head light are you running any other electronics? There's always been battery issues with mine... if i keep it on the battery tender I can get a few years out of one... Dad seemed to have to buy a new one every spring cuz he would just roll it in the shed when the rain set in and not touch it till about march.
                        After installing now my 3rd battery in 8 years I've figured out the problem... The spliter on the CB to adapt it to controls on the mic is wire hot all the time. so when in the off position the power led stays on. Now this doesnt sound like much. But remember we're dealing with a battery with a lead plate 1/4 the size of your standard car battery. Even after sitting on the tender my blinkers don't like to work while idling untill I've riden it for a few miles... GREMLINS
                        Now did you have this problem before you bought the new battery? or is this a new gremlin
                        I usually dont want to jump to the conclusion that maybe theres a crack in a cell or plate in the battery... but puppies die new all the time
                        Don
                        old:
                        1989 kawi ex500
                        1996 yzf-r6
                        1999 yzf-r1
                        2001 kawi zx-6r
                        2000 Ducati 748
                        2002 YZF-R1
                        2005 V-Star 1100 Classic
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          Ba80-Idle is set at 1100 and holds steady there, the carbs has stock jets (put them back in last rebuild 2mo ago with full rebuild of carbs)
                          Dragon- No acc. on the bike, OEM all the way except the headlight bulb, batt volts check in spec at idle and at 2500 rpm
                          I am going to replace the OEM fuse box, clean all grounds and connections and check water level again, charge completly again and give it a try
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            I've ran a walmart battery in "old man" and my old ninja... worked great in my ninja. lasted 18 months in "old man" ymmv
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                              OEM, make sure your charging system is up to snuff. At least 14V at the battery at 4K rpm. The Wal-Fart batteries are fine, only if you use them every day or so, they don't like to sit, AGM type doesn't mind as much.
