Leaky Petcock
  • ddragon63
    • Jan 2012
    • 1101
    • Ridgefield, WA
    Originally posted by GLoweVA
    I did modify my petcocks a little. I ground off the little nub at the top so I can rotate to the 12 o'clock position and have and 'off'.
    I like that, so that I KNOW that the thing will not flow at all.
    This is especially useful when you go to pull the tank off and you take the hoses off the petcocks and THEN you find out that one of them leaks because the diaphram isn't seating right.
    That sounds like a good idea...
    Don
    old:
    1989 kawi ex500
    1996 yzf-r6
    1999 yzf-r1
    2001 kawi zx-6r
    2000 Ducati 748
    2002 YZF-R1
    2005 V-Star 1100 Classic
      The mod for the "Off" position on the Standard taps works great... unless the diaphragm is bad and then it leaks too!
        I run a single Standard tap modified for an off position with a pingel inline vac fuel shutoff. I got tired of those integral vacuum valves leaking even after rebuilding.
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          like previously stated this one only drips when put into "prime" posistion. So i'm gonna assume either the sealing face is pitted or rubber seal is rubbed up in that area... I would think @ worse a new rubber seal and a shine of the surface and it should be golden. I've left this thing with gas in it for months on end in the "on' and/or "res" position and have never had an issue... as soon as I put it in prime to put some gas in the carbs... drip. Once moved back, done
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
            Is that drip coming from the carbs or from the tap itself?
            • ddragon63
              • Jan 2012
              • 1101
              • Ridgefield, WA
              comes out of the tap... right @ the handle
              Don
              old:
              1989 kawi ex500
              1996 yzf-r6
              1999 yzf-r1
              2001 kawi zx-6r
              2000 Ducati 748
              2002 YZF-R1
                The wave washer probably needs bending a bit, not gonna know till you got it apart. Maybe for reassembly use some white lithium grease on the moving parts. Thats good that it's not carbs leaking.
                • Cobia
                  • Jul 2007
                  • 1587
                  • Palm Beach County, Fl
                  Pardon the inaproprieteness but ........
                  When your "pet cock" leaks all the time, it's time to go to the doctor and get some penicillin......
                  Sorry, my devious mind couldn't pass it up....!!
                  1980G Standard, Restored
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  1980GH Special, Restored
                  '82 XJ1100 (Sold)
                  • ddragon63
                    • Jan 2012
                    • 1101
                    • Ridgefield, WA
                    It burns doc.... it burns
                    Don
                    old:
                    1989 kawi ex500
                    1996 yzf-r6
                    1999 yzf-r1
                    2001 kawi zx-6r
                    2000 Ducati 748
                    2002 YZF-R1
