simple question on small oil seepage
    The only thing the service manual fails to state is to have the bike on the centerstand when removing the tensioner, otherwise the chain can fall off to the left of the crank sprocket and next thing you know, you have bent valves.
    • ddragon63
      • Jan 2012
      • 1101
      • Ridgefield, WA
      +1 ya I forgot about that... that should always be step 1 on most any repair... thanks Phil
      Don
      old:
      1989 kawi ex500
      1996 yzf-r6
      1999 yzf-r1
      2001 kawi zx-6r
      2000 Ducati 748
      2002 YZF-R1
      2005 V-Star 1100 Classic
        draggon, that leak from tensioner is a hint to replace it with an auto-adjuster......would seriously consider it........good insurance and beats the cost of the alternative.....
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          Ya I've considered that option. Thanks for the input
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
          • ddragon63
            • Jan 2012
            • 1101
            • Ridgefield, WA
            Found the oil leak
            So its been located.... I cleaned the CCT and road the bike a couple times this last weekend. The plug @ the end was my seeping oil "problem child" I fixed it with some RTV. will keep an eye on it.
            Thanks for all the help guys
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
              Works until rubber plug comes out completely.....and it will eventually as they get hard from the heat. Just like anything else, has to be sealed from inside out......not other way around as that is just a bandaide at best. Will work until your a hundred miles from home and you suddenly have warm pant legs with a dark saturation........theres a pair auto CCT's on the bay off a Venture Royal 1300 for less than 50bills........JAT.
              • ddragon63
                • Jan 2012
                • 1101
                • Ridgefield, WA
                Thanks for the impute moto... What are the fitting models for the auto cct. What about theading the end of the cct and and pipe plugging it. Or putting in a freeze plug. A rubber plug seems out of place in that spot for sure
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                  Hey Dragon,
                  Multiple techniques have been used. A fellow used a bottle cap with RTV!
                  It's a NO PRESSURE oil leak spot, so it shouldn't take much to seal it. The threaded/tapped idea with plug and possibly JB Weld would be a good technique also!
                  I put a big glob of RTV on mine many years ago, and it's still sealed well. YMMV!
                    Actually there are several that fit and work. Two that are commonly used are out of a Venture 12 or 1300, any year V-max(same motor as Venture), 550Vision(have to elonggate upper hole in tensioner), all plug and play, just follow original tensioner adjustment instructions.......all of course on centerstand unless it's missin'..... still HAS to be upright and vertical
                    • ddragon63
                      • Jan 2012
                      • 1101
                      • Ridgefield, WA
                      Hey Dragon,
                      I have read alot of posts that a glob of RTV has worked for many other people.. I like the idea of an Auto CCT but I'm not fully sold on the idea (as I've posted in others threads) It takes about 5 minutes to adjust the chain if you know what tools to grab out of the box. I may look into it further and possibly change it when i do the timing chain down the road.
                      Don
                      old:
                      1989 kawi ex500
                      1996 yzf-r6
                      1999 yzf-r1
                      2001 kawi zx-6r
                      2000 Ducati 748
                      2002 YZF-R1
                        If you want to do drilling and tapping, you can make it into a manual no slip tensioner and it will never leak out the front again, JAT. Then again, you don't even need to drill, just run a 3/8" tap thru and RTV the threads of the new front lockbolt.
                          I like this one...
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            ok i'm lost I'm assuming your referring to behind the front plug???
                            sorry... not following
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                              Yup... Adjust once every 10K
                              • ddragon63
                                • Jan 2012
                                • 1101
                                • Ridgefield, WA
                                I got ya... not a bad idea. set it when you check the valves I'm gonna assume?
                                Don
                                old:
                                1989 kawi ex500
                                1996 yzf-r6
                                1999 yzf-r1
                                2001 kawi zx-6r
                                2000 Ducati 748
                                2002 YZF-R1
