i installed the wiesco 1190 kit and wondered where i should start with my jets. it's a 11sf. i live at 580 feet above sea level. thanks in advance.
1190 kit
Start at the stock jet sizes and check plugs frequently and adjust as needed.Nathan
Theodore Roosevelt -
Stock
+1 If everything else stock? If so I would starts with stock jets. You have increased the volume bt 9.25% so you will move more air, but you also move more air as the rpm increses on the stock bore and the carb jets handle that fine with the stock exaust / timming etc. then see how it runs and adj as /if needed
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
In that case
In that case, I would ask Phil and others, Phil has made a chart (couldn't find a link) that he has said works well for bikes with mods as far as jets go
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Hey Lucky,
In the MISC forum is the Jetting Guide for mods, and when combination of mods there is a little simple math to do...but again these are just guides/starting points to try, but still need to monitor your plugs.
I've done the smaller 1179 kit, but also have 4-1 pipes and Indy filters, with later 81 carbs, I'm running 117.5 mains across all. My dyno run after breakin showed that I could have possibly put in 1 more size to 120's, but I've got good color and performance to redline, so I haven't tried the larger size. I had been running the 42.5 pilots because of one that was corroded/frozen in place 10 years ago, and I didn't have the tools or confidence to attempt to remove it. This last year I took a small drill and then easy out to it and was able to get it out, so I put in the 45's that I had ordered 10 years ago!
I ran OEM jets (110's) for 9 years with the 4-1 pipes alone with stock airbox, but after the big bore and Indy Pods I didn't want to take any chance of burning a hole in my new pistons, so I followed the jetting guide! YMMV!
T.C.T. C. Gresham
