1190 kit
  • 1190 kit
    i installed the wiesco 1190 kit and wondered where i should start with my jets. it's a 11sf. i live at 580 feet above sea level. thanks in advance.
    Start at the stock jet sizes and check plugs frequently and adjust as needed.
      Stock
      +1 If everything else stock? If so I would starts with stock jets. You have increased the volume bt 9.25% so you will move more air, but you also move more air as the rpm increses on the stock bore and the carb jets handle that fine with the stock exaust / timming etc. then see how it runs and adj as /if needed
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        1190 kit
        i have pod filters and 4 into 1 pipe. also have a set of 1980 carbs i can use if they are better. thanks
          In that case
          In that case, I would ask Phil and others, Phil has made a chart (couldn't find a link) that he has said works well for bikes with mods as far as jets go
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            Stick with the early carbs if running a non-stock combo as they're easier to adjust...
              1190
              thank you for the information
                Hey Lucky,
                In the MISC forum is the Jetting Guide for mods, and when combination of mods there is a little simple math to do...but again these are just guides/starting points to try, but still need to monitor your plugs.
                I've done the smaller 1179 kit, but also have 4-1 pipes and Indy filters, with later 81 carbs, I'm running 117.5 mains across all. My dyno run after breakin showed that I could have possibly put in 1 more size to 120's, but I've got good color and performance to redline, so I haven't tried the larger size. I had been running the 42.5 pilots because of one that was corroded/frozen in place 10 years ago, and I didn't have the tools or confidence to attempt to remove it. This last year I took a small drill and then easy out to it and was able to get it out, so I put in the 45's that I had ordered 10 years ago!
                I ran OEM jets (110's) for 9 years with the 4-1 pipes alone with stock airbox, but after the big bore and Indy Pods I didn't want to take any chance of burning a hole in my new pistons, so I followed the jetting guide! YMMV!
