Air-Craft Paint Stripper
I decided to take the paint off down to the bear metal.
Could anyone, who has used this, explain to me the procedure I should use.
Like the best way to apply, how long do I leave it on and how to clean it off.
I'm sure I could figure something out
but;would rather have the benefit of the collective's experience.
Thanks in advance
but;would rather have the benefit of the collective's experience. Thanks in advance
Good luck with your bike
The Aircraft remover will strip the paint, bondo and anything else the PO did to trip him up. It rinses off with water and if any care is taken to get it clean, it will not bleed back through as the water turns it harmless and a little sanding is all that is neede to prep the metal. You really don't need the self eteching primer if you sand it right (as that primer is ment for alum and composit metals) So he has the stripper 0 extra $, rinse water, pennys, sandpaper, guessing has some or can buy a small amount cheap, Primer filler 5 bucks, done right and lasting for a long time, PRICELESS
