I'm in the midst of doing a winter clean and polish along with some maintenance. I want to take off the clutch and alternator covers to use my bench mounted buffing wheels and want to know what to expect upon removal.
Clutch cover - my manual says simply to remove the clutch cable but makes no mention of removing the release arm. Any hints on how to get that stubborn nut loose?
Alternator cover - same manual and it says not to remove the 3 allen screws in the middle of the cover. Why not? Also says to disconnect the battery and some wiring with an aim to removing the alternator itself. I just want the cover off for cleaning. Should I anticipate anything frightening (bits and pieces falling out) if I just remove the cover?
What is attached to the inside of this thing?
Thanks as always.
What is attached to the inside of this thing?Thanks as always.
