80SG front foot peg rubber replacement
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    So, don't hate me, but I got NOS replacement rubber for my SG for 1$ (+s/h)here:
    Here's my question:
    How do I get the old ones off? (without totally destroying them)
    I read somewhere that to get the new ones on, just spray the post with a little hairspray.
    I'll take a pic tommorow showing what I got and to show some of the internals to the shaft and stuff.
    I figure that the old rubber might be better than my current ones on my G so I can swap those out too.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Old one
    The Old one is most likely toast, cut it off. You can put in in the oven at 200 for 10 min and hope it will lossen up. As to install the new one, warm it up, then dish soap and water will help it slide on and when dry, it will hold like new
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • trdriver71
      • 360
      • Edmonton Alberta
      I would do it like I put on hand grip and put in into a bowl with some very hot water like some that was boiled in a kettle let sit a couple of minutes then try and remove using gloves as the part will be hot.
      '79 XS11SF
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Rubber
        The rubber is so much tougher on the foot pegs then the handlebars. They take lots of work to get on. The dish soap hepls and heating the rubber parts helps also, but still a b!tch to get on. Two guys with gloves and a bench clamp to hold the part, lots of soap and hot rubber, and you still need some luck IMHO
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          • 8083
          Lube them with Armor All or something similar. I use it to install the carburetors, air box, tires, etc. The product I usually use is CARQUEST Vinyl & Rubber Dressing. It looks like grape drink. Armor All will work just as well.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            A thought on tubular rubber pieces.
            When pulled from one end, they tend to get smaller inside.
            (think Chinese finger trap).
            When pushed on the end, they tend to expand inside. If you can figure a way to support the inside edge of the rubber, and press the outside of the steel peg, with some lubricant, it might press out.
            That would mean a press would have to be used.
            I'm sure the factory used a press to put them on.
            CZ
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              I "think" they might have been molded on from the factory, that is whay I say th OEM is toast But, if you are replacing it, it must be toast anyway, so cut it off. The reason I said use a vice to hold the peg, is, that way you can push it on like CZ said and use expanding rubber as you push, instead of contracting rubber if you tried to pull it on. Ther reason you use dish soap as a lube insted of oil or other stuff, is, when it dries it loses all lubracating properties and helps hold the new part in place instead on letting it stay slippery, not a good thing on a foot peg when rideing, good luck with your bike
              CZ
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
              • Danny Crawdad
                • May 2011
                • 239
                • Birmingham, Alabama
                If they are anything like mine, just save yourself the time and cut them off . I tried heating mine with a heat gun, spraying lube in, etc. on them and ended up destroying them anyway trying to get them off. Best I got was using a screwdriver to lever the end, and then pushing off from the inside, but that rubber is tough, and will come apart before it stretches much, especially the old ones.
                But I may be wrong, maybe mine were glued on .
                Hairspray recommendation is great for the grips too
                XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
                Well, goodness. Look what we've got here.
                  • 2104
                  These are what I use on stubborn jobs like this, usually the larger ones. YMMV
                  http://www.harborfreight.com/catalog...yword=pick+set
                    • 8083
                    George,
                    What do the old ones look like? If they're still good, leave them on until they aren't. If they're no good, split them with a knife. Eventually, they fall off. BTDT
                      • 2104
                      Jat...
                      Oh yah if you have an air compressor you can insert the end of the blow tube under the outside edge of the rubber and with the free hand form a seal around the inside edge, give it a shot of air and simultaneously squeeze and pull and they may come off in one peice. This method works well on stubborn handgrips. YMMV
                      • Lamric
                        XStremely XSive(Deceased)
                        • 410
                        • Kenley, Surrey, England
                        There's a ridge on the footrest that holds the rubber on, use a flat blade screwdriver to lift the rubber away from this and it'll slide off. (
                        (left one shown)
                        Brian
                        XS1100 LG "Mr T", SG "ICBM" & FJ1200
                        Check out the XS Part Number Finder
                        Be not stingy in what costs nothing as courtesy, counsel and countenance.
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          Brian, thanks for the pic of the peg frame. That helps alot.
                          Marty, the current ones are decent,(the ends are comming off) but I've got the new ones and I want to make the bike look good!
                          I plan on eventually using the old rubber on my G, once I find the proper pegs.
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                            • 2104
                            Disregaurd...
                            ...my suggestion with the air compressor as that method clearly won't work for your situation. Thanks to the pic from Brian my memory of this task has resurfaced
                            GLoweVA, I have an extra set of front pegs in good condition from my '80G, if you have trouble with the R&R of yours, that You may have for the cost of shipping if you'd like. LMK
                            • GLoweVA
                              • Jun 2011
                              • 1957
                              Schming, My 80G currently has the wrong pegs on it. ( I think they're the older 78-79 ones. (not wide))
                              My SG has the not so bad rubber that I'm replacing with the new rubber.
                              If the ones off your 80G are okay, I'd love to have them for my G.
                              Then I can compare the rubber on those and see if I want to but my old SG rubbers on those or not.
                              Thanks,
                              ps. Go Steelers!
                              The Green Monster
                              Got him in '04.
                              Scarlet
                              Got her in '11
                              Hugo
                              Cold weather ride
