Update on my 80SG project & Question
  • STEPPENWOLF
    • Jan 2007
    • 4188
    • CINCINNATI OH
    Those are wells for EGT (exhaust gas temp) probes so the factory could adjust, and then seal the carbs. You should have these on all four head pipes if the exhaust is original, but a PO probably swapped on pre-80 outer pipes/mufflers...
    Not being a mechanic...
    Are you able to get a little more specific on adjusting carbs and then seal?
    I am not a wrench turner but I try to understand the basic principals.
    I have the wells and never knew why they were there.
    '80 XS1100 SG
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Carbs
      Steppenwolf after 1980 they made modifications to the valves and the carburetors mainly to meet emissions requirements. Part of what was done was to reduce emissions. In an effort to reduce the owner adjusting idle mixture they actually put a plug in over the idle mixture screws that most all bikes have removed now. What was done to measure the non burnt fuel was put ports in the exhaust to do sampling. There are places where cars have to do emissions testing to get a valid inspection and these were ports to also to do those tests. If you have the proper equipment and a copy of the original tech tip you can actually tune a carburetor to make the bike run cleaner. Up until last year Yamaha actually listed those tech tips on the 1980 G model of the parts lookup. Now all that is listed is the LG and SG models Not all exhaust had the ports but based on what I saw you could originally take the bike back for the update just like recall mods on cars. They also had information on putting on heavier shocks and other modifications like vacuum advance.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • Rasputin
        • 3193
        • Lacombe, Alberta, Canada
        I have a number three exhaust vale sittinjg here in a head I will no longer be using. I will check it out and see what it looks like if you still need one. Let me know. Shipping only if it is ok once I get it out.
        2-79 XS1100 SF
        2-78 XS1100 E Best bike Ever
        • STEPPENWOLF
          • Jan 2007
          • 4188
          • CINCINNATI OH
          Wow...ViperRon..here I thought they were there to just drain condensation in the winter
          Thanks and I am sure there are few others thinking the same thing.
          '80 XS1100 SG
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            Sorry
            I sincerely apologize for the mistake of addressing this message to you Steppenwolf rather than GloweVa who was the original person requesting information. What I wrote was intended as a help for GloweVa but as I put your name on it, it appeared a hateful slam. Not my intent at all.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
            • STEPPENWOLF
              • Jan 2007
              • 4188
              • CINCINNATI OH
              Gee..I thought I was "SPECIAL"..
              See you somewhere down the road.
              '80 XS1100 SG
              • GLoweVA
                • Jun 2011
                • 1957
                • Virginia Beach, VA.
                I like the read on the EGT ports from ViperRon, Thanks.
                Rasputin, Can you check that valve out for me? Thanks. Saved me $25 for ording one.
                I'll PM you.
                80G (Green paint(PO idea))
                The Green Monster
                Got him in '04.
                bald tire & borrowing parts
                Scarlet
                Got her in '11
                Ready for the twisties!
                81H (previously CPMaynard's)
                Hugo
                Cold weather ride
                • Rasputin
                  • 3193
                  Pulled the remaining three exhaust valves from that head and all were slightly bent. Sorry.
                  2-79 XS1100 SF
