clutch
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Clunks
    Clunks Yea, they did that when new the whole "shifts like a Russian tractor" thing I am glad your bike is working well, the clutch in these holds up well for many many miles if you adjust it and use good oil
    Originally posted by bcknblkbird
    and so i adjusted my clutch today, it engages closer to the grip now, still clunks when put in first and most likely always will, rode it two miles seems to be working fine no slipping so far. thanks for all those who offered advice you guys rule!!!
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • petejw
      • 2269
      • sydney australia
      if the bikes idling a little high at idle itll
      clunk into 1st more so, but these are known
      to clunk into gear at the best of times.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        +1 Pete, and I have found if you pull the clutch in and hold for a few sec. and give it time to disengage, the "clunk is less
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
