Older tops on Newer carbs
  • Older tops on Newer carbs
    Anyone know of a good reason I should not use the tops from an older set of carbs 78/79 on a newer set 80/81. The only difference I can see is the smaller post for the spring to sit around.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
    That would do it for me right there. With the smaller post, the spring would be able to wander at the top and might cause things to bind making the vacuum piston not work properly.
      That is exactly what I was wondering Cy. I am trying to think of a way to stabilize it without being to bulky and causing other problems. I could just use the later tops but the gold on them is so pitted that even after sandblasting they look terrible, so I am looking at other ideas.
      2-79 XS1100 SF
        Stick four dabs of JB Weld around each post, then cut/file it to the right diameter. Although I've seen early tops on late carbs with no problems, so it might be worth trying...
          The top of the spring is flat. The surface around the cone on the cap is also flat. Install carefully. They will be fine.
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
            Sand / Buff
            You could sand the right ones smooth with 320 then 1000 grit, then polish them to look like chrome with a buffing wheel and metal polishing compound
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              The later type tops are steel, not aluminum, so once they're rusty/pitted replating is the only fix....
                Ok
                Cool, I didn't know that What about primming, sand / filling the pits then painting them with chrome / alum paint
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  If you're going for the 'OEM' look, that won't cut it....
                  Couldn't resist....
                    Alsa
                    Here is the paint I use for that kind of stuff, looks pretty close to OEM to me
                    http://alsacorp.com/products/killerc...e.htm#showcase
                    It is kina pricey, but I have 5 spray cans of the "killer chrome" I would sell for 1/2 price + S/H if intrested
                    Couldn't resist....
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      That looks great
                      Lon that looks like chrome to me!
                      Nice job.
                      John
                      '81 XS1100H - "Enterprise"
                        Holy crap, That's some good chrome paint, pricey, but I think it might be worth it for some applications.
                        81 XS1100H
                        • #13
                          I am going to paint all the gold parts of the 81LH a different color including the wheels so I am not really worried about the chrome. Thanks for the idea and I may want to use that on future projects, just not this one. I do know the flat tops and flat springs should not move, but I wanted to know what you fellows thought.
                          I just used my caliper to find the depth of the spring keeper is also different as the later ones are 7.5mm and the earlier ones are 10mm. I just do not want to find out after prep and paint that I made a major goof. Thanks to everyone for the input.
                          2-79 XS1100 SF
                          • #14
                            I didn't comment earlier because I didn't have any closeup photos of mine.
                            I've got the later 81 carbs, and I sanded them to remove and smooth out the pitted cracked chrome surface. I then primered and painted and clear coated with the same stuff I did my tank/fenders with! I think they look good.
                            • #15
                              Godzilla
                              Way to cool TC, Godzilla rules
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
