Anyone know of a good reason I should not use the tops from an older set of carbs 78/79 on a newer set 80/81. The only difference I can see is the smaller post for the spring to sit around.
Older tops on Newer carbs
That would do it for me right there. With the smaller post, the spring would be able to wander at the top and might cause things to bind making the vacuum piston not work properly.Cy
I was always taught to respect my elders, but it keeps getting harder to find one. -
That is exactly what I was wondering Cy. I am trying to think of a way to stabilize it without being to bulky and causing other problems. I could just use the later tops but the gold on them is so pitted that even after sandblasting they look terrible, so I am looking at other ideas.2-79 XS1100 SF
Couple of more parts bikes of which 2 more will live!Comment
Stick four dabs of JB Weld around each post, then cut/file it to the right diameter. Although I've seen early tops on late carbs with no problems, so it might be worth trying...Fast, Cheap, Reliable... Pick any two
The top of the spring is flat. The surface around the cone on the cap is also flat. Install carefully. They will be fine.
'81 XS1100 SH
Sep. 12th 2015
RIPComment
Sand / Buff
You could sand the right ones smooth with 320 then 1000 grit, then polish them to look like chrome with a buffing wheel and metal polishing compound
That is exactly what I was wondering Cy. I am trying to think of a way to stabilize it without being to bulky and causing other problems. I could just use the later tops but the gold on them is so pitted that even after sandblasting they look terrible, so I am looking at other ideas.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Last edited by XS1100_OEM4ME; 12-14-2011, 02:02 PM.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
That looks great
Lon that looks like chrome to me!
Nice job.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
81 XS1100HComment
I am going to paint all the gold parts of the 81LH a different color including the wheels so I am not really worried about the chrome. Thanks for the idea and I may want to use that on future projects, just not this one. I do know the flat tops and flat springs should not move, but I wanted to know what you fellows thought.
I just used my caliper to find the depth of the spring keeper is also different as the later ones are 7.5mm and the earlier ones are 10mm. I just do not want to find out after prep and paint that I made a major goof. Thanks to everyone for the input.
I didn't comment earlier because I didn't have any closeup photos of mine.
I've got the later 81 carbs, and I sanded them to remove and smooth out the pitted cracked chrome surface. I then primered and painted and clear coated with the same stuff I did my tank/fenders with! I think they look good.
T.C.T. C. Gresham
Godzilla
Way to cool
TC, Godzilla rules
T.C.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
