Splatter
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Splatter
    Everytime I go for a ride, I get a slight splatter on top of the left side muffler behind the front peg It is not much, I checked the main crank seal, shaft boot, both OK, and the overflow batt line is down past there and through the frame loop Any guesses
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    What is it that your getting on there? The material that the splatter consists of is key in where to look for the source. Do you need depends?
    I'd look at the cam chain tensioner, it's a common leak point on these bikes, and it could cause splatter back to that area if the flow went just right. Also check the valve cover for leaks, that's another possible source of leakage as long as you have ruled out the rider as the source.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      Well that depends I would have thought that kind of blow-by would have shown up on both sides Did you know diarrhea is hereditaery, yes, it runs in your genes, or is the jeans
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        • 8893
        Could be the neutral switch.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Realy, that is what is so puzzeling, there is not a drop of oil anywhere on my motor Not even under around the oil filter or anywhere on the crank case. New valve cover gasket with no leaking, the old one was fine also, just replaced last month when I did a valve adj, cam ten is as dry as Greg county in Texas. Just a gremlin I guess
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • CatatonicBug
            • 6117
            • Clinton, UT
            That was my thought too.
            • Rasputin
              • 3193
              • Lacombe, Alberta, Canada
              Any chance that it may be middle drive. Could be the vent tube for that. Another idea would be coming from the rubber boot drain on the drive shaft, oil from rear seal on middle drive could leak it there. JAT
              2-79 XS1100 SF
              2-78 XS1100 E Best bike Ever
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                rubber boot drain on the drive shaft? I am not sure where that is? Didn't know there was one, will look for it as that could be the cause
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  Ahh, that's a good call from them, I forgot about that. There is a hole in the rubber boot between the middle drive and the swing arm, which is USUALLY on the bottom if it's installed correctly which will allow any leakage from the middle drive (or liquefied grease from the drive shaft area) to drip out onto the ground, but it can fly up onto the exhaust there when your riding. Check the bottom of the rubber boot to see if it's oily/greasy to get some idea if it might be coming from there.
                  • Rasputin
                    • 3193
                    Is there any news on the splatter front? Any time there is an unexplained marking oil wise on these bikes I get very interested
                    2-79 XS1100 SF
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      Jeans
                      I was the running in my jeans thing
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                      • Rasputin
                        • 3193
                        Seriously....you posted that...lol. Oh well I know where the leak was now...lol... Have fun today and every day
                        2-79 XS1100 SF
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          Shaft boot
                          For real, I think my shaft boot leaks a little grease, (not hypod oil, as that is never low) I am happy about that, I would rather have a little extra comming out of my shaft, then uncontrolled leaking from my rear end at my age
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                          • Rasputin
                            • 3193
                            Cool to hear you did not have a serious issue happening. The rear end leakage is something I will leave alone...lol
                            2-79 XS1100 SF
