I got a good deal on a wire harness so I have been cleaning connections and testing continunity. One of the missing parts is the connector for the tip over switch. There is just a black and a black/white wire sticking out. I checked all the old posts I could find for a bypass and they all say just unplug the connector. If there is no connector, do I connect these wires together or ensure that they never touch. Thanks in advance for your help, the knowledge base here is priceless.
Tip Over Switch
Tags: None
Leave the black/white disconnected and not touching anything; the tipover switch grounds out the TCI to stop the motor. The black is ground, the black/white goes to the TCI...Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
HOWEVER,
The switch is there to shut the motor down in the event of a tip-over. If you fall down ( it CAN happen, DAMHIKIJK
) and don't have the switch, the motor keeps running, etc... etc...
Hi DaVinci,
in the unlikely event of my sidecar rig getting flipped on it's side and me surviving the flip, will the switch reset itself when the bike is turned back upright or will I have to know where it is and how to reset it?Fred Hill, S'toon
"The Flying Pumpkin"Comment
Tom
1982 XJ1100, waiting resto to originalComment
Don't take it to harshly, it is hard to impart intent in a typed message. It is a good idea to have the manual for the bike, and its easy tog et a PDF version, just look for a post or the member page for Catatonic Bug, he host the manual on his personal web site.
that tip over switch is a good feature but not a fool proof either. When I had my "incident" with Thunderstruck, the bike got leaned against the guard rail and wound up riding the guard rail till it hit a support post and then got flipped.Life is what happens while your planning everything else!
78 XS750Comment
IIRC, I read somewhere that the switch operates when the bike is beyond a 60 degree angle. that is practically ON THE GROUND. That may be why it didn't activate for you?Don't take it to harshly, it is hard to impart intent in a typed message. It is a good idea to have the manual for the bike, and its easy tog et a PDF version, just look for a post or the member page for Catatonic Bug, he host the manual on his personal web site.
that tip over switch is a good feature but not a fool proof either. When I had my "incident" with Thunderstruck, the bike got leaned against the guard rail and wound up riding the guard rail till it hit a support post and then got flipped.Former owner, but I have NO PARTS LEFT!
I agree with why it did not activate, I just meant that having that switch is not a guarantee that the bike will be shut off when you need it to be for safety reasons. It is not a bad thign to have on the bike, but IMHO, I would not go through the trouble of rewiring to add it if it were missing.Life is what happens while your planning everything else!
78 XS750Comment
