bad flasher unit??
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    bad flasher unit??
    checking all the electricals, I've noticed the left signal operates as it should, but the right flashes maybe 2 times, then goes solid lit. If its the flasher, wouldn't it affect both left and right? What can cause this, bulb going bad, corroded switch...or?? Still looking for a special tail light lens, the small square one.
    81 XS1100H
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    light
    I am guessing both f/r bulbs are working? If so, is this only when bike is not running, if so, low or going bad battery could be your cause. Some times one side will require more current then the other side (old wireing, poor grounding etc) and with the bike running, the charging makes it work better If even when running at a good rpm, I would check / clean the handlebar switch
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      Already thought of that, has brand new battery, and double checked the charge. Both front and rear signals work, when the right quits flasing, both front and rear right lights stay lit.
      81 XS1100H
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Running?
        Running or not?
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Automotive bulbs can cause a similar issue............that's partially why scoot bulbs are specific to scoots.....JAT...
          • old_skool
            • Nov 2011
            • 554
            • Ohio
            sorry, not running, have to finish the carbs first to try it in running mode
            81 XS1100H
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              99%
              99% sure it will work fine once running, mine does the same thing after sitting (new battery in mine also) clears right up after the first ride, XS gremlins
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
              • old_skool
                • Nov 2011
                • 554
                • Ohio
                Originally posted by XS1100_OEM4ME
                XS gremlins
                Sorry, no passengers, gremlins please disembark the vehicle with your hands up!
                81 XS1100H
                  I agree that the problem will likely be diguised once the engine is running. However, I'd say the handlebar switch is in need of some maintenance. There are a bunch of connecitons in there that are known issues, so take the whole thing apart and clean the contacts, re-solder the wires as needed, and lube the whole thing with a nice coating of dielectric grease. Having the right bulbs may well be an issue too, since the flasher is reliant on the current that the bulbs draw to tell it when to flash. It's a bit of a safety thing that tells you when a bulb is out.
                    I'd bet a new cheapo $3 two prong flasher will fix it. No more self cancelling though. The OEM flasher unit comes apart and the contacts can be filed down like you would an old set of breaker points.
                    A million other Yami's use that tail lite lens (79SF)....
                    http://www.boats.net/parts/detail/ya...521-60-00.html
                    • old_skool
                      • Nov 2011
                      • 554
                      • Ohio
                      Appreciate all the help and suggestions!!
                      81 XS1100H
                        Hi Rich,
                        my best guess is a partial ground fault. Along with every other ground connection, check the continuity between the signal's pot-metal casting and the steel threaded tube that holds it on; nasty crystals can grow in there.
                        • old_skool
                          • Nov 2011
                          • 554
                          • Ohio
                          I figured I'd be going through all the grounds and plan on adding a few new ones, engine to frame and more. Thanks
                          81 XS1100H
                          • cywelchjr
                            XS-XJ Super Guru(Deceased)
                            • 4450
                            • Sacramento, CA
                            And if you want the best of both worlds, you can do the two prong flasher and implement the auto cancel mod to retain the auto cancel function as well and have your cake and eat it too as I do .
                            • old_skool
                              • Nov 2011
                              • 554
                              • Ohio
                              I haven't read much on the electronics of these bikes yet, how does the self canceling work and how did you integrate it with an auto flasher?
                              81 XS1100H
