replacement carbs
  • old_skool
    • Nov 2011
    • 554
    • Ohio
    Looks like the Suzuki carbs already had the vacuum advance port.
    81 XS1100H
    • petejw
      • 2269
      • sydney australia
      on the suzuki carbs the outlet on number 2 carb
      is for a vac petcock, it doesnt work the same way
      as it does on the mikuni carbs, the vac adv on the
      mikuni carbs uses ported vaccuum.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        • 8862
        I've ridden behind a 79F with ZRX carbs and I'll tell you that bike was quick. We were riding mountain roads and sweepers. I remember Chris (Yamahansolo) was having some difficulty tuning them though. Good mod for some extra power.
        • 81xsproject
          • 3185
          • Fortuna, CA
          one of my bikes has kz1000 carbs - seem the same to me except the enrichment is different but otherwise work ok. not any easier. no noted benefit - i think they were used by PO if I recall due to not finding XS carbs.
          John
          A KZ1000 sits next to the XS in my garage. The carb spacing is drastically different and unless you modified the spacing, I would be shocked if this is true. The KZ had straight intake boots which made for a large space between the center pair of carbs to compensate for the cam chain area. The old VM and BS equipped Suki's had the same spacing as the KZ.
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
            • 8050
            I just had a look at a KZ1000 Police. The carburetors were Mikunis that look like what's on the Yamaha. I suppose you could use them if you used the XS space bar and linkages. This of coarse, after the supply of XS1100 carbs completely dries up.
