petcocks for 79 special?
  • Jelmo11
    • Nov 2011
    • 45
    • Sidney, Ohio
    Ok so my petcocks are leaking horribley and the are in the off position I have rebuilt them and still they leak I'm lost and need help is there another fix or what guys help me out here
    You could try bending the wave washer a bit to tighten up the pressure on the selector mechanism. When you say they are leaking from the off position, are they dripping on the engine or still leaking thru the spigot?
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Petcock
      They are kinda basic, if you put new gaskets and seals in them. Did you make sure the post was lined up with one of the 4 holes in the new gasket and press in the lever without twisting the seal out of place Also, the two screws can leak if not OEM with good gasket / washers on them, and check to make sure the tank is metal to seal on the "O" ring that mates it (the factory seals are ovel not round, but the round ones will work
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        That would be my question, did you actually install new seals, or just take them apart and clean them out? It's the seals that go bad usually, so leakers almost always need new ones. A couple of other things to check, is the lever 'face' (that goes against the large seal) smooth/flat? If that's damaged, they can be impossible to stop from leaking. Sometimes 'resurfacing' that on some ultra-fine sandpaper until all pits/scratches are gone will do the trick, but again, you'll need new seals as the originals will probably be bad from the bad lever. Also make sure the surface that goes against the tank is flat; I've seen these slightly bent and they won't seal. If you pull the filter towers off, run a file across the surface until it's flat.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Petcock? am I allowed to say that?
          As to the inside of your petcocks being to rough to not seal, never heard of that, as they are sealed from MFG till now? Just make sure that the "NEW" gasket is in place with the post that holds it there If you are useing old gaskets and seals, BUY NEW ONES, they are cheap and all over Ebay and others And remember, the gas might be leaking from the tank seal / screws most dont leak from inside if rebuilt
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            better pictures
            Hey, my new leaf, here is a completly covered babe that I hope I can share
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              Hi Lon,
              not if you don't stop shuffling your photobucket albums, even the XS11 link in your signature don't connect.
                I have opened up a petcock or two that had the maing surface of the lever pitted from sitting in bad gas or empty tank. Using 600 grit paper followed by 1000 grit cleaned them up nicely.
