exhaust mod
  • chewie123
    • Mar 2010
    • 34
    • New York
    exhaust mod
    Do you guys think using kerker headers to a supertrapp muffler would work for our bikes? Ive been reading on here a lot about back pressure and performance, and i understand i will lose a little in the low and mid range but i was thinking with the supertrapp i could tune it easier to have more back pressure with the internal discs and then jet accordingly.
    here is the muffler - http://www.ebay.com/itm/SUPERTRAPP-4...item3cbd4c4e82
    thoughts?
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    They should work fine even if the OD/ID of the connection points are different, you can adapt those. And you're right, the SuperTrapp gives you more latitude for tuning your system. Although, as long as you're not running pods and straight pipes, getting the right combination of jets shouldn't be that hard.
    On my G I'm running a 4X1 Kerker with a drilled airbox and I'm using the stock jetting, and it runs perfectly fine....!!
    The PO told me it was rejetted when they put in the Kerker but I discovered it wasn't. It was running good so I left well enough alone.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I have an RC Engineering 4 into 1 exhaust on my bike. It came with nothing in the muffler ($45 on Ebay). I have SuperTrapp baffle in it. Started with 20 discs and now down to 8 discs.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • Cobia
        • Jul 2007
        • 1587
        Hey Pat,
        My J came with the RC Engineering exhaust and with the baffles. They sound really nice too. And once again, when I got into the carbs, they were jetted to stock specs... go figure.
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        '82 XJ1100 (Sold)
          Apology for the short thread hijack,
          Pat, Cobia, could you post a few photos of your pipes/headers. I was told a long time ago that my pipes that I had gotten from JCWhitney in the early/mid 80's were RC Engineering. Then a few years later some other folks told me that they were MAC! They had NO LABELS on them when I got them. I'm sure JCW contracted with one of the exhaust manufacturers to make the pipes for them. I had actually NOT heard of RC Engineering. I think I had heard of MAC a few years later. I'll post a few different views here so that perhaps you can compare them to yours and help me to confirm whether mine are really RC or MAC?? Thanks in Advance.
          Showing the muffler off of the headers, the bend, etc.
          • Cobia
            • Jul 2007
            • 1587
            I'll take some pics tomorrow. They're actually off the bike now.
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            '82 XJ1100 (Sold)
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              I wont be home till next week. Ahhhh, life on the road.
              Pat Kelly
              • chewie123
                • Mar 2010
                • 34
                • New York
                Cobia, I actually have been running pods with stock exhaust with no rejetting - runs great but i bet ill have to re jet finally if i go with the exaust swap. Pat - good to know its working for you - i'll try out with 8 disks to start with. Is yours pretty loud with 8 in there?
                c
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  It's luod enough that I feel bad when I fire it up at midnight (or 4 am) to go to work. I don't like loud pipes at times like that. The tone is good though.
                  Pat Kelly
                  • Cobia
                    • Jul 2007
                    • 1587
                    Better late than never ???
                    TC,
                    I finally got around to digging my RC Engineering exhausts out to get them ready to install on the J . I found no marks on the pipes, only a badge on the muffler. Here are the pics:
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    And finally painted:
                    [IMG][/IMG]
                    [IMG][/IMG]
                    You can kind of see the emblem in this picture:
                    [IMG][/IMG]
                    Hope that helps.
                    Kerker 4 - 1
                    850 Rear End Mod
                    Automatic CCT
                    '82 XJ1100 (Sold)
                      • 8077
                      That looks quite similar to what's on my SG. The main difference being the four header pipes are not welded to the collector.
                      • Cobia
                        • Jul 2007
                        • 1587
                        It then may be a Jardine (good) or a Mac (not so much) because the Kerker on my G is welded. But I have a SS Jardine 4 x 2 turnout that's not welded.
                        I also saw a NOS 4 x 1 Jardine on ebay that was not welded either.
                        Either way it's better than the alternatives..... some franken exhaust or a very overpriced new one.
                        I was looking at some RC Engineering exhausts for FZ1's that almost looked as if they could be 'coerced' into fitting our XS's.
                        Kerker 4 - 1
                        850 Rear End Mod
                        Automatic CCT
                        '82 XJ1100 (Sold)
