carb rebuild?
  • DCracer25
    • Jul 2011
    • 179
    • harpursville NY
    carb rebuild?
    where can I get a decent priced carb rebuild kits for my 81 xs1100 venture? and front fork seals and dust covers?
    • 8796
    Carb kits P/N 48-1408
    Fork seals P/N 27-1012
    Fork dust boots P/N 27-1087 (these are listed incorrectly on partsnmore.com and should fit an 81 Standard)
    http://www.partsnmore.com/parts/yamaha/xs1100/?filters[fitting]=custom
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Jat
      JAT, I would just replace the bowl gaskets "if needed" most can be reused if not damaged. Unless you are changing the jet size, just clean the OEM and re-install, the rest is a waste of money IMHO
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        Agreed, unless there is damage everything can be cleaned.
        • DCracer25
          • Jul 2011
          • 179
          • harpursville NY
          carbs
          thanks for the info I took the bowls off and found what looks like real fine rust particles, other than that they were real clean. I think I need to check the gas tank.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            In that case I would remove the tank, clean it inside well, just make sure everything is out of the tank Next, check all the screens, petcock and needle vavles screens (I would add two inline fuel filters in between the carbs and tank. Open up and clean out the petcocks, even if they arent leaking, get the rust and junk out, a little oil on the seals then reassumble
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              On an 81 I would beg to differ. The o-rings on the needle valves really need to be replaced as part of the rebuild process unless they have been replaced recently. However you can get them as part of the o-ring kit at harbor freight and have a bunch of others besides, other than that, I fully agree that unless there is damage or you are re-jetting there is no need to replace parts.
                There is also the viton tipped needles that get hard and don't seal properly anymore. Still probably cheaper to just get the bits needed annd not the whole kit.
                • DCracer25
                  • Jul 2011
                  • 179
                  • harpursville NY
                  Thank you all for the info, pulled the tank drain the gas and looked inside the tank and found alot of surface rust inside the tank, next question is how do i clean it out and do I have to seal it some how?
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Por
                    POR, red coat and others make a complet kit including rust remover, metal prep and sealer, if that much rust, might be a good idea to do it now while you have it apart, even if it doesn't leak "YET" if it is rusty, it will sometime and you don't want rust getting into the rebuilt carbs Here is the POR kit
                    and others
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • DCracer25
                      • Jul 2011
                      • 179
                      • harpursville NY
                      thankyou all for the info will be ordering the gastank kit and get a oring kit as well I am going to order the fork seals and dust cover because mine are leaking.
                      • Ebenezer
                        • May 2011
                        • 67
                        • Hawley, MN
                        What do you guys think of the set of carb kits on Ebay from Carb Kit Capital that have the gasket and the o-ring included for $49.95 for a set of 4? I have been looking as well, and just found these today. Like you said if all the other parts aren't necessarily needed, is this set a decent deal? I was going to buy
                        the complete kit from Georgefix, but if not needed I guess I won't.
                        Ryan
                        1981 XS1100SH
                        K&N filter
                        Spade fuse block
                        Barnett Springs
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          If you have the stock jets and they arent damaged, all you need is the "O" rings (forgot about those as my Special doesn't have them) If the gaskets are in good shape, re-use them, clean the crap out of the rest of the parts (I soak the jets and emulsion tubes 24 hours in carb clearner, then clear with compressed air) If you need the bowl gaskets, this guy sells 8 for $12.00, you have to ask if your bike is not listed, but he can cut most
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                            • 7765
                            Try this link: http://www.xs11.com/forum/showthread...t=electrolysis
                            This should take care of the tank. For the carbs, you have someone in Florida that sells on ebay under the name georgefix. I use him for ALL of the parts I need for carbs. I think he may have a brick and mortar shop under the name hardparts, but I'm not sure.
                            With the '81, you MUST replace the "O" rings on the seats, as well as the needles. I just bought a kit for an '80 Special, with extra jets, for about $76, and another $35 for the octy/petcock kits. It is worth the money, in my mind.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              Driver
                              Not picking on anyone, and not trying to start a fight But I respectfuly disagree. After buying all new kits for my bike with all new parts, I ended up removing all the new jets and replacing with the OEM 30 year old ones. If you have the factory jets and other parts and they are not damaged, you will be hard pressed to improve on them with aftermarket kits IMHO The "O" rings are a easy fix, just buy new ones at a fraction of the cost of a kit I know many offer complet kits, I bought 4, and now they are in a bag and the old OEM are on the bike
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
