Source for Fork Seals
  • Barnfresh
    • Mar 2009
    • 160
    • Abilene, TX
    The last step to get Shankapotomous legal is the state inspection, so I headed out to the Yamaha dealer first thing this morning. The inspector wiped his finger accross the front brakes under the forks and said my fork seals were leaking and it would not pass... bummer.
    Of course they did not have seals in stock so I thought I would order online. Meanwhile I cleaned up the rotors and under the rubber caps on the forks with brake cleaner and went to the Harley dealer to try again.. That guy really liked my bike and rode it and looked it over pretty good... all legal now, but I still want to get some seals. Any suggestions on the best seals and supplier for '80 standard?
    When the horse is dead, dismount.
    Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
  • Elevener
    • 608
    • small town in TEXAS
    Everyone has them, Dennis Kirk ships fast
    https://www.denniskirk.com/cruiser-m...aha-xs1100.mmy
    Trapped in time. Surrounded by evil. Low on gas.
    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
      • 8753
      If you still plan on using air assist, then I would use OEM Yamaha seals $$. If you have fitted hevier springs and don't use air then I would use some cheaper standard seals, like K+L's from Georgefix web site. If the tubes are pitted/dented, then I would use Leakproof brand, JMHO, YMMV.
      Edit: I've used the Parts Unlimited brand $10/pr from DK with no problems, but on non-damaged tubes. A few pits will eat them up.
        +1 stated by Phil.........and I would use OEM either way. Least there still available for the Standard.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          Oem
          +1 on OEM, considering all the work to install and get back on the bike, why take a chance Here is a set of OEM for $36.95 + S/H for Special if anyone need them
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            OEM seals fo a G
            $17.76 each +S/H for a G
            http://www.boats.net/parts/detail/ya...145-00-00.html
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              good find on the Special fork seals seeing they are no longer available OEM for the Special or XJ.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                79SF seals from Yamaha are $30.00 each
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  Whatever a few suppliers may have left............better grab 'em if your aboarb a Special/XJ
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Motoman
                    Hey Motoman, I agree with you. My was because the only other seals I could find to pass on to the group was twice as much You are right about, get them now if you need them because there arent many out there to get!
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • xs11lover
                      • 1433
                      • Montoursville Pa
                      Georgefix has them in his store for $11 and a nice pile of other rebuild parts too. I've been getting things from him for years...always the right price and shippied very quick.
                      79 XS11 Special (Lazarus)
                      79 DT 100
                      • Barnfresh
                        • Mar 2009
                        • 160
                        • Abilene, TX
                        Georgefix it is. Thanks. Now I just need to get those babies down into those long silver tubes..
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          Motoman & I
                          We were talking Yamaha OEM seals, aftermarkets are still out there from many sources, but there is a "BIG" differance If you plan on pressureizing the tubes or they are less then perfect surface, they will leak alot sooner then the OEM IMHO
                          http://www.ebay.com/itm/79-81-XS1100...item2c5d0daa3b
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                          • xs11lover
                            • 1433
                            • Montoursville Pa
                            Make sure you get the right ones...special and standards are not the same. He has both.
                            79 DT 100
                              Originally posted by XS1100_OEM4ME
                              We were talking Yamaha OEM seals, aftermarkets are still out there from many sources, but there is a "BIG" difference If you plan on pressurizing the tubes or they are less then perfect surface, they will leak alot sooner then the OEM IMHO
                              Hi Lon,
                              2 years back I replaced my bike's oil puking fork seals with whatever make it is that Dennis Kirk sells. FWIW they still stay pumped up.
