Tach needle ?
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Tach needle ?
    Are the Tach Needles and Speedo Needles interchangeable?
    My SG has a broken off tach needle (It's just a nub)
    I saw the tech tip on the faceplate refurbish and he just pried the needle off with a fork.
    So, I'm trying to figuring out where can I get a needle.
    Any ideas?
    Maybe one of you out there has a junk meter (speedo or tach) that you can sacrifice the needle for me. ?
    Thanks
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    You might also go to a scooter place that caters to Oriental scooters, and see if you can get a dead speedo from them.
    The needle on a Kymco 50cc scoot looks like the same needle as is on the XS. JAT, CZ
    • GLoweVA
      • Jun 2011
      • 1957
      I suppose when I get around to pulling the tach apart, I can pull the needle off and go down to the yamaha dealer and see what they might have in the service dept.
      Hopefully someone there might be nice and give me a dead one that isn't worth anything to them.
      The Green Monster
      Got him in '04.
      Scarlet
      Got her in '11
      Hugo
      Cold weather ride
        I have a speedo I just swapped out, and the plastic housing is cracked. If you want it, it's yours for shipping cost. The hard part is going to be accessing the needle. You can't get to it without cutting off the metal ring that holds the glass to the front of the gauge.
        • GLoweVA
          • Jun 2011
          • 1957
          Thanks Bug. That'd be great.
          The tech thread here: http://www.xs11.com/xs11-info/tech-t...especials.html
          talks about prying the metal lip with a small screw driver to get the face off and then using a fork to pry the needle off.
          I'll PM you with my address and stuff.
          Thanks again.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
          • petejw
            • 2269
            • sydney australia
            i tried doing a swap the other day,
            the thingy the needle slides on is a
            slightly different size and doesnt fit,
            ull need to get a tach needle for the tach.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • GLoweVA
              • Jun 2011
              • 1957
              Pete thanks for that little piece of Intel. Bug is gonna send me a speedometer. I'll try my best to make it work. Maybe if I have to I'll glue the sucker on there.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
              • petejw
                • 2269
                • sydney australia
                no worries george, let us know how u go.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                  That's weird, Pete, maybe the RH models are different. I've swapped the tachometer and speedometer needles between US model Standards and Specials and the needles are all balanced and fit the same.
                  Once you have the bezel and the glass removed you can carefully twist the needle off the tachometer spindle. The galvanometer has positive mechanical stops inside it but the needle doesn't so you won't break anything.
                  The speedometer is a little trickier because it has a stop pin for the needle but not for the mechanism and the spindle is preloaded with spring that will relax after you take off the needle. Take the speedometer assembly all the way out of the inner housing. Mark the metal bell on the inner end of the spindle and its shroud with a pencil or a laundry pen when the needle is at rest so you can put the needle back on with the original spring preload and Barbara is your mother's sister.
                  Hold the speedometer assembly in one hand with your thumb against the bell to keep it form turning, then carefully twist the needle off the spindle with your other hand.
                  Assembly is reverse of disassembly.
                  FWIW I used the plastic fork the first time I worked on the speedometer but I wouldn't do it that way again. Even if you're really careful it'll leave marks on the old oxidized black paint on the face plate and trying to fix them will leave clean marks on the old oxidized black paint.
                  • petejw
                    • 2269
                    • sydney australia
                    lol scott, it wouldnt be the 1st time,
                    the spindle the needles fit in were a different size
                    on my bike, i wouldve thought they were all the same.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      Hey George,
                      Those needles are quite delicate anyways, mine had broken apart just from sun exposure, aging, and then shock/vibration alone!
                      Scott, I wasn't worried about the tach face because I had plans to replace it anyways, but I'm sure scratches are very possible using any method to pry the needle up off the spindle. I guess just pulling up on the needle with something that would provide even pressure on both sides of the needle/spindle junction would be good. Oh...Duh...reread your post about spinning/twisting the needle up and off the spindle since it has stop points.
                        Yep, T.C., the needles will break or crumble if you look at 'em wrong. Wait! Strike that! They'll break or crumble even if you don't look at 'em
                        The black paint on the dial face has a fine surface texture to it that if you magnify it looks a lot like a sprayed acoustic ceiling so that it will back-light at night without glare. If you touch the dial face it doesn't really scratch the paint as much as it scuffs or compresses the 'fluffyness' and leaves a mark. Trying to remove marks, oil or grease from the dial face it is almost the same as trying to fix a sprayed ceiling. It can be done but it's not easy on something that will be sitting about two feet away from your face for thousands of miles.
                        After repairing my 160 MPH speedometer using your Tech Tip -- thank you very much for that again by the way! without visibly messing up the speedometer face I decided not to use a fork when I repaired the tachometer. Everything was going just fine until I gave the needle that one last twist to seat it in position and I left a half-circle mark in the paint with my fingertips. Argh!
                        After the last five needle repairs/replacements I've gotten a little better at it.
                        • petejw
                          • 2269
                          • sydney australia
                          scott, just out of curiousity, when u removed the
                          needles, did the little brass 'thingy' that sits on the
                          spindle and inside the needle, did that part stay
                          on the needle or the spindle?
                          looking at what i have
                          the outside diameter of the brass 'thingy' look the same but the inside diameters
                          were slightly different in size as was the spindles.
                          were your spindles the same size for both the tach and speedo?
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                            Spindle and Needle
                            Pete, here's a picture of a disassembled (broken) tachometer and one of my collection of pet broken needles.
                            On the inverted needle mount base you can see the counterweight and the melted plastic blobs where the needle is attached but there is no brass bit anywhere. The speedometer and tachometer needles are identical.
                            Click the image:-
                            XS1100 galvanometer spindle and needle mount base for the tachometer.
                            • petejw
                              • 2269
                              • sydney australia
                              scott, heres a pic of the back of the broken needle
                              from mine.
                              does look different to yours.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
