crank seal ignition side.
  • guycom
    • Nov 2011
    • 13
    • Sea Bright, NJ.
    Does the ignition side of the crank take the same seal as the alt side? I have oil under the timing plate... Thanks
    Guycom
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    No
    No they are not the same. Here is the parts for a 79
    http://www.boats.net/parts/search/Ya...TON/parts.html
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      O ring temp fix
      What has been done on cars and might work on these bikes, is the O ring fix You clean the shaft and seal with paint prep cleaner (leaves no film and wont eat the seal) Then you put a "slight" film of oil on the shaft close to the seal. Next you slide an O ring down againest the seal and put a bead super glue around the seal and O ring (It melts the rubber parts togather and the oil film you put on the shaft keeps it from sticking to the shaft) I havent tried it on a bike, but should work
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • guycom
        • Nov 2011
        • 13
        • Sea Bright, NJ.
        First thanks for the info OIL SEAL (S-32-48-7.8L-HS) i'm going to try my local auto parts store and see if they carry it. Gluing the o-ring is an interesting idea but if the seal is around $10 as the stator one was I think ill invest in it.
        Guycom
          • 8767
          A bearing supplier will have that seal, BTW there is no outer lip on the replacement seal, otherwise the cases would have to be split. I'm sure you have already read up on the subject. The RS alternator crank seal is 32X45X7, the LS crank seal is 32X48X8.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Cool
            Thats cool I thought you had to split the case to remove the old one If not, tap in and ride on
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              • 8767
              Naw, you can pry/cut it out with a little bit of patience. Always apply some RTV to the outer edge before tapping the new seal in.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Cool
                Thats cool Looked like from the pic's that the seal was installed from the inside and had a lip to hold it there I am not big on scraping and scuffing the crankcase and shaft If it works for you guys, it must work
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • Barnfresh
                  • Mar 2009
                  • 160
                  • Abilene, TX
                  How about that..
                  My shoes were oily after riding today - the left side is leaking and the right side is seeping... I thought I would check here and see how to fix these seals. The first thread I saw has it all - complete with sizes and part numbers. I love this site! BikerPhil rocks!
                  When the horse is dead, dismount.
                  Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Please
                    Please let me know how that works
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • Barnfresh
                      • Mar 2009
                      • 160
                      • Abilene, TX
                      crankcase venting
                      As far as the leaking crankshaft seals - I was wondering if part of my problem may be from excessive crankcase pressure forcing oil by the seals. The crankcase vents through the 3/8 OD hose coming from the top of the transmission up to the airbox. If that is clear than all is well? There is no breather screen anywhere? What to folks with pod filters do - just vent overboard?
                        Unless you plugged that there should be no way for pressure to build up. And besides, those seals are under pressure anyways from pressurized oil any time the engine is running anyways, so even if the crankcase got pressurized it wouldn't affect THOSE seals (just others). It's one of the reasons those are important, as they ARE under pressure when the engine is running, and the faster the engine is turning over the higher the pressure is.
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          Just asking?
                          OK, just asking I don't understand how the crank shaft seals are ever under pressure except gravity. They don't run in the pressure curcit (IE, cam, rods, mains) that recive oil under pressure from the oil pump I do see where the heat thins the oil when running and the spinning of the shaft inside the seal will increase the leak, even more so if the crank bearing is loose
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                            Well, if you look at the bearing, and where that seal is (both of them), there is the bearing, and the oil can go two ways, and the only thing that keeps half the oil from exiting the engine is that seal. Granted it wouldn't be a LOT of pressure, but it would be some as the oil trying to come out from under the bearing on that side has nowhere else to go other than get pushed back the other way by the seal blocking any further oil going that way. So pressure will build up against the seal just from that. I'll bet if you could find a way to measure you would get something a LOT less than main oil pressure but I'm pretty sure you would have positive oil pressure on the back side of that seal.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              Wow
                              WOW, I am just learning Oil gushing out of the crank bearing and causing pressure on the crank seal WOW, how could I have missed that Are you for real
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
