crank seal ignition side.
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Oil
    Dumb me, I thought the oil race down the middle and the drain holes were where the oil went. I never thought the shaft seal was what sealed the crankshaft You learn something every day
    http://www.boats.net/parts/search/Ya...TON/parts.html
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      No matter what, in order to keep the bearing fully oiled, there must be enough pressure to force oil out from under it, and some of it does go to that seal. That's why a seal has to be there, that's NOT a dry spot, but it's not splashed either.
      BTW, that's NOT a drain, that's a pressurized feed line to provide oil to the rod bearings, and I believe to the other mains as well, but they may be fed individually from the case, I haven't looked at the drawings to see that part, but I can tell you, that channel and those holes are not drains, those are under pressure. Drainage just like all the other bearings is out the sides of the bearings, it's how oil pressure is maintained, the oil has to SQUEEZE out past the bearings through the bearing clearance to get out, otherwise if it went through that big hole, you would have no pressure, and that's why an engine with worn bearings will have low oil pressure as one of it's symptoms.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Wow
        Wow, I learned something again I thought that the oil pump forced the oil through the crankshaft then through those groves and accross the bearing surface I guess all those years I spent as a high performance motor builder and all the schools I went to for mechanical engineering got it wrong What do they know, they just design these things
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          CY, I am just having some late night fun, You have been a big help on these bikes to me and many others Just two guys saying "MINES BIGGER" I love you man, and keep up the great work helping all of us keep these antiques on the road
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • cywelchjr
            • 4450
            • Sacramento, CA
            And where do you think the oil GETS to the crankshaft? Those passages there are how it gets to the crankshaft and to the passages to feed the rest of the bearings. I've built more than a few engines, had more than a few courses in engine maint and design, including in the military.
            But since you already know everything that's fine, I'm done trying to discuss the issue. This will be my last post on the issue.
            I will not respond to anything further in this thread, go ahead and do what you will.
