tank size
  • Jelmo11
    • Nov 2011
    • 45
    • Sidney, Ohio
    tank size
    Ok I'm curious as to what the tank size is of the special vs. The standard tanks the american versions and about how many miles you get out of each tank full
  • Lamric
    XStremely XSive(Deceased)
    • 410
    • Kenley, Surrey, England
    Brian
    • Jelmo11
      • Nov 2011
      • 45
      • Sidney, Ohio
      Originally posted by Lamric
      Can anyone verify this?
        • 8767
        I thought American Standards with the exception of the 81 were 5.3 gal. and all the Specials were 3.8 gal.
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          They are. What is on that chart is in British(Imperial) Gallons.
          5.3 = 6.36gals
          4.4 = 5.28gals
          3.3 = 3.96gals
          Richard
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            UK gallons are a little bigger than US gallons.
            I don't know what the conversion factors are.
            Here's what I've got from the manual:
            Standard 5.3 US gal
            Special 3.97 US gal
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • hamjam
              • 1003
              • Toronto ontario Canada
              [QUOTE=GLoweVA;347066]UK gallons are a little bigger than US gallons.
              1/5 th as a result of some Tea party in Boston
              Seamus Ó hUrmholtaigh
              Niimi Moozhwaagan
              and SOXS
              2008 Nomad "Deja Buick'
                • 5061
                The american H model (aka venturer) has a bigger tank than the american E, F, or G standards. It is about a US gallon more.
                • hamjam
                  • 1003
                  5.3 = 6.36gals
                  4.4 = 5.28gals
                  3.3 = 3.96gals
                  1 Can Gallon = 1.201 U.S. Gallons
                  1 U.S. Gallon = 3.785 Liters
                  1 Can Gallon = 4.546 Liters.
                  Niimi Moozhwaagan
                  and SOXS
                  • b.walker5
                    • Feb 2009
                    • 1745
                    • Invercargill, New Zealand
                    Extra US info added.
                    • Irukandji
                      • Apr 2011
                      • 75
                      Venturer Fuel tank appearance
                      Guys...does the tank have the fuel gage mounted in the side of the tank?
                      Want to know how I can tell a 6 gal tank from others w/o actually comparing
                      the size in person.
                        the size in person.
                        The only way to do that is to look closely at the knee indent in the side of the tank. On the 'standard', the forward edge of the indent is very rounded, the larger Venturer has this line 'straighter'. Once you realize this, it's fairly obvious....
                        • Irukandji
                          • Apr 2011
                          • 75
                          Thanks very much Steve. It s very helpful
                          • Lamric
                            • 410
                            Check out the angle between the filler cap and the front of the tank.
                            This is the smaller standard tank...
                            This is the larger standard tank...quite a hump
                            Brian
                            • Joab
                              • Aug 2010
                              • 472
                              • Ozark, Alabama
                              Hmm...I think I need a closer look. Someone should probably go ahead and send me a Venturer tank so I can make sure I know the difference
                              Joab
                              "If nothing else, it will be interesting..."
                              ______________________________________________
                              1979 XS1100SF
                              1972 XS2 650
                              Ozark, Alabama
