[QUOTE=petejw;347011]ive done the same mod as phil for the tensioner,
i just used a bolt and a rubber o ring behind the washer,
have done it on 3 of my engines,
the side bolt in the pic does nothing more than preventing oil from coming out.
and u just need to be careful not to overtighten the chain.
workes really well.
I found the quote button after my last post. So how much tension should I use to insure I don't overtighten the chain?
workes really well.
That cylinder will have little or no compression during the test!
IF any bent valves found, then it's OFF WITH IT's HEAD anyways to fix that! Good Luck.
