1978 XS1100 First Ride.....WOW!!!!
    Originally posted by jmacsuga
    I am spit shining the bike. Long winter, lots of snow, and well, you know the story. Anyway, while working on my '79, I am finding time for this little jewel. You might like the complete results, but I am in the process now of doing the front forks, and this is how far I have progressed so far. Go to http://jimphoto.freeprohost.com/Yamaha78
    Hi Jim,
    Buying a bargain bench grinder and mounting polishing mops on it will be more economical than replacing those power drills as they burn out.
    And the forks are forking pretty but what about the insides?
    Polishing off the flaking clearcoat on the outside of the sliders won't improve the fork performance at all.
    OTOH taking the fork to pieces and washing out 30+ years-worth of crud from the insides won't show at all but will most likely make the bike ride nicer.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      $79.00
      Here is one for $79.00 including S/H 3/4 HP Includes two polishing pads
      http://www.northerntool.com/shop/too...5081_200485081
      Hi Jim,
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • anarchy18
        • Sep 2011
        • 134
        • Germany
        Im glad theres hope
        Im so very THANKFUL for your quick replys and that i didnt buy my guage for nothing!!!!!!!!! But only 1 problem Dudes i live in Germany out in the boonies!!!! .....gonna have to order em so i need a name for them and where they are sold seperately cause I cant find em on EBAY OR ELSEWHERE?
        '81 Yamama XS1100 5K7 German Model
        What's the difference between erotic and kinky?
        Erotic = using a feather
        Kinky = using the whole chicken
        • Lonerider62
          • Nov 2011
          • 187
          • Gaylord, MI.
          #34
          Cam chain
          One more thing I've discovered I need for my restoration is a new cam chain. The adjuster was all the way extended so I think it's best to replace the thing now rather than having to go back in at a later date. I was able to split the master link OK and that was no biggie but my search for a new one is provng to be a PIA. Bike Bandit is out of stock as well as Old Bike Barn. I tried PNM but couldn't find one, just master links, plus I find their site rather hard to navigate and cookies is a problem for me. I did find a company by the name of Panther Chains but they sell a few difererent sizes i.e. regular, Heavy duty, etc. Does anyone else know of a source? One other thing that caught my eye was while changing out the mid and rear-end gear oil, although the oil itslef didn't look all that bad, the fine metal powder from the gears that had collected on the magnets was far more than I've ever seen on any other machine I've owned. Could it be that I'm the first guy in 31 years to check those two things? I mean There was a ton of crap accumulated on those things.
          Can't beat the smell of gas & oil
          • Prothec
            • Jul 2007
            • 587
            • Fort Myers, FL
            #35
            I personally use a 4-way gang valve with a single vacuum gauge and open one valve at a time.
            http://www.amazon.com/Hagen-Elite-4-...2051172&sr=8-3
            This is actually the valves I have, they just came in a plastic holder from Jack's Aquarium and Pets:
            What you need are pretty much just a plain old plastic or metal valve. There are a ton of options with aquarium supply, you just need the right size for your tubing.
            Here's an example of 2-way valves:
            http://www.amazon.com/Plastic-Valves...051753&sr=1-54
            Website/Blog
              Cam chain and cam chain link...
              http://www.z1enterprises.com/catalog...S1100-1979-EN0
              • dogyear58
                • Aug 2007
                • 45
                • cold country minnesota
                #37
                Late entry here
                WoW, if you think that one is fast.......
                Ride my first year standerd With 4 to 1 drag header,
                Over size cams, Slide carbes, Right on the money tune up.............
                I'm bilding one now 2nd generation engin with first gen. head..
                Over 10 to 1 comp.....ouch.... Thanks from the dog........
                81XS1100sp full dresser.
                79XS1100sp rat bike.
                • jmacsuga
                  • Oct 2011
                  • 58
                  • Spokane, Wash.
                  #38
                  No need for bench grinder.......Polisher????
                  Thanks for the suggestion, Fred!!! While I have it apart, I think I WILL take the forks apart and do as you suggested!!! As far as getting a bench grinder, this works best for me.........http://jimphoto.freeprohost.com/Yamaha78/yam78_025.JPG I use this when I have the part off the bike and can do it standing up!!! This one, I assure you, WON'T burn out!!! Jim
                  Hi Jim,
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    #39
                    Valves
                    One of these should deliver to where you live
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • anarchy18
                      • Sep 2011
                      • 134
                      • Germany
                      #40
                      http://www.google.com/search?source=...w=1280&bih=598
                      U serious man these will work??? which ones EXACTLY Its for this sucker right here:
                      http://www.ebay.de/itm/290485257112?...84.m1423.l2649
                      I need 4 of whatever u posted but im still not sure exactly which ones will work and fit my hoses and if they are adjustable how am i gonna get all 4 of em open to the same exact specs? Originally there was a peice of fine bore thick wall clear plastic tube to do the dampening but your saying these little valves will do the same thing? If a $1 part does the job.....AWESOME!!!!!
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        #41
                        For controlling the spiking on vac gauges for carb sync, you adjust each valve till the gauge almost stops moving, then do the next one till all 4 barely jump at all, any of the adjustable ones will work, the fish tank tubeing is about the same size as the carb tool tube
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                        • anarchy18
                          • Sep 2011
                          • 134
                          • Germany
                          #42
                          I have read so many post on here lately that I am not sure I am talking about the same thing, is this for controlling the needle spiking on vac gauges for carb sync If so, that is what I am talking about, you adjust each valve til the gauge almost stops moving, then do the next one till all 4 barely jump at all
                          Ya we're talkin bout the same thing!!! Thats what i needed! Which ones would work exactly tho incase i order? I got some aquarium stuff in the basement and have to look at what i got and i might get lucky!!!!!! WOW MAN U GUYS GOT SOME AWESOMER THAN AWESOME IDEAS ON HERE!!!!!!!!
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            #43
                            The idea is not to get the "exact" same resistance at the valve, it is just to calm the gauge so you can read it, they will all have a different amount of vacuum till in sync, just make sure you dont close any of them completly or the gauge will not move when you adjust the carbs
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • anarchy18
                              • Sep 2011
                              • 134
                              • Germany
                              #44
                              You make it sound simple enough. Ill try it out!!! Glad I hung on to the guage after the last mechanic shop told me its a peice of crap and now i just figured out that its just cause this little $1 peice was missin? WOW, HOW LUCKY CAN I GET?
                                #45
                                If you really want to go lo-buck, try this: http://www.xs11.com/forum/showthread.php?t=986
                                Same idea, only with a single gauge. Works every bit as well, just takes a bit more time. One advantage is you don't need to worry about gauge calibration (i.e. do they all read the same) as you use the same gauge for each carb. This is what I use...
