Breake HELP!!
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Breake HELP!!
    OK, got my new front pads for my xs1100sf. Go to put them on, one pad is thick at the top the other at the bottom. Follow PO's install, then "I THINK" that might not be a good idea again I am on the right front set, they are installed with the "outside" pad with the "thick at the top", is this correct, and if so, do both sides go with the"outside pad" with the thick at the top pad
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    if i remember rite....the pads are stamped on the back for left and right side.
    after that is established, they can't be installed wrong as the pin that goes thru the pads to keep them from falling out can only go thru one way.
    testing 1-2-3
    1980 1100 mns
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      Thanks
      My new EBC's weren't stamped or marked on the pads or package or came with instructions, nor does the Cylmer man help, BUT, I did do a referance by the part # and determand which was Right and Left, and from there, you are correct, can't put them on wrong
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        Hey there OEM,
        Glad you figured out your pads problem. But you still have a problem, and we'd like to direct your attention to this thread for some additional help!
        http://www.xs11.com/forum/showthread.php?t=34566
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Give me a Brake LOL
          Hey there OEM,
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            • 8930
            Oops, this link is broken....try again later.
            • mikubuilder
              • Jul 2011
              • 548
              • Westland, Mich.
              thanks TC for this much needed lesson
              Nick
              1982 Virago 750 (it's alive!)
