Idle pre-set position?
  • Idle pre-set position?
    I did a pre-sync on my '80G carbs and forgot to write down my idle position. Anyone know what it is?
    1980 XS1100G = Current Project - 1980 XS1100LG = Dormant
    Idle st
    I just went through my carbs and if you are talking where to set the idle fuel mix screws, I would start at 1 3/4 turns out, then color tune (what I am working on now) If you are talking about the total idle screw (the one that opens all 4 carbs, I would just hold them up to the sun light and turn till you see them open, then back down till just a little light can come through
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      I'm confused. By pre-sync, do you mean setting the butterfly valves to the same open position?
      You set the idle with the bike running, usually around 1100rpm.
      Then with the idle set, then you can sync the carbs with some kind of vacuum rig.
      Hope this helps.
      When you ask questions, it's useful to give more information like bike model and year and specifics to your questions.
      EDIT: Just read the 2nd post from OEM4ME and to add to his comment, I set my idle mix screws at 2 turns out to start, then dialed them in after i sync'd them.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        Okay, I set all of the butterflys the same with a wire-tie wire. Will it idle at this setting?
          As long as your idle mix screws are out at least 1 to 1&1/2 turns she should idle just fine. (may be a little high like around 2k or so)
          You may have to use the choke to get her started and warmed up, after that then adjust the idle set screw to get the idle set at 1100rpm.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
            Thanks all, I will start it where it is and see what happens.
              when u look at the butterflys, have them only slightly open at best
              if there open to much the bikes idle will race on start up, keep a hand close
              to the kill switch in case that happens to shut it down quick, if
              that happens back the idle screw off a bit.
              once the bikes running u can then set the idle to the correct revs
              around 1100rpm
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
                +1
                +1 Pete, that is why I said to hold up to the sun light and turn till you can see light comming through, then back off till just the least bit of light comes through
                around 1100rpm
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  That is what I needed to know. Thanks again.
                    Wire
                    Any wire tie (thinkng you are talking about a bread twist tie type) would be "WAY" to open for idle That kind of gap will have you at "to the moon" RPM''s. Just the least bit of sun light comming through each carb will be a good starting point
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
