It's been done, so the answer is a qualified yes. There's an upside and a downside (as always!
) with doing this.
The upside is you can fit a wider tire (up to 6.25" wide) with the stock tube gone.
The downside is the FD end of the shaft has no seal, so retaining the grease in there (and keeping out contaminates) becomes an issue. It may be possible to address this, as the XS750/850 does have a seal in there, so that might be something to look at. I'll also note that you can get longer driveshafts (if you want to do a stretch), as there's a company making replacement shafts for the V-Max and you can get custom lengths. The main drawback to these is the shaft is considerably larger (it seems the V-Max is known for breaking these), so larger-than-stock tires again become a problem.
