Has any body put a set of these carbs on?
Kiehin 39 mm
Tags: None
kiehin 39 mm
WOW!! All alone on this mod? Mech says we can make them work.They fit the bike, as there on it now.Any help on set-up would be great.They sure look great on the bike.Nice combo with the campell x-pipe. Can't wait to get it running to hear the sound. -
+1 on what Trash said.
Details, we want details.
Sounds like you might be on new ground here.
Nothing like being a trailblazer that we can all learn from.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
Not familiar with the carbs either but the 36mm carbs from a ZRX-1200 are on mine and are like night and day over the OEM carbs. If you have a vacuum madvance mechanism on your bike you might need to tap one of the carbs for metered vacuum for that.
Do a search on ZRX carbs here and you might find some helpful infor on what to do with your carb set.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
39mm is a big jump from 34mm originals
Its possible to get them to run but with such a bigger choke size the air flow velocity through them will be a lot lower, this will mean you'll need to go a lot bigger on main jets and possibly needle jets to get the fuel flow to match the air flow to compensate.
I have some 36mm Keihins from a Kwak, they're big compared to the original carb rubbers but fit Ok, how have you fitted 39mm carbs to the XS1100 engineTom
1982 XJ1100, waiting resto to originalComment
kiehin 39mm
These are fcr 39mm flatslides and seem to fit the stock rubbers fine.I'll try to get some pics up.Comment
What part of the set up? Gas lines will be easy. Just get a t if it has a single fuel hose. Also when I went to the keihn I had to use a throttle cable from a Suzuki bandit 600. 94 I think. Other than playing with the jet sizes that's all I had to do. You need to let us know the jet sizes currently on there. Pilots mains and air if it has them will it crank like it is? Does it stumble. All these thing will help us no which direction to go.
P.s. they might be too big airflow wise. I used to own an 86 Radian and it was faster than its fj600 brother in the 1/4 by 2 10ths if I remember right. And the radians carbs were smaller. I think that was the only difference. Ill like for the article when I get home.Last edited by yamahansolo; 11-03-2011, 07:03 PM." She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairingComment
Not exactly the same, but this will show how the hole needs to be located....
Still at it and still buying things.Last was a Tommaselli domino push pull throttle.Relocating all handlebar switches.Installing dirt tracker seat.Will get some pics up soon.Comment
Well hurry up...lol...following this thread...
1980 gs1000g "stock"
2008 jmstar 150cc Chinese scooter ( wife's bike)Comment
39MM Kiehin carbs
Have had the bike running all summer with these carbs(39mm Kiehin flat slides) .They are something else and turn the bike into a different machine.I also put a 1/2 turn dirt bike throttle on it.When you grab a hand full you better be ready.I'll get some pics up soon.Comment
