Petcock fuel filter?
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    As some of you know, I am "Trying" to get my bike as "like new" as possable While rebuilding my petcocks last night I heard the top fall inside the tank from one of the filters / screens So I decided to fix so it couldn't fall off again. I took it out and tried to run a small pice of wire through the screen on both sides at the top to twist it over the cap to hold it in place. Well the screen riped Do any of you have an extra petcock filter / screen for a 79 SF that I could buy for a few bucks, new one's are $$ And any pointers on how to "permenitly" attach the top that constently baths in gas Thanks
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    No spare filters (that are any good that is...), but I had the same problem on the SG filters; I fixed it by pressing the top in place, then 'spot welding' it with a soldering iron...
      I have an XS650 with the identical petcock to the XS1100 standard. I'm sure it's the same plastic pressed in standpipe/screen as the Special. The XS650, being a 360 degree parallel twin, vibrates a good bit more than the XS11. My standpipe vibrated out, just as yours did. I figured it out when I needed "RESERVE" and there was none. I removed the petcock, and carefully pressed the standpipe back in. No hammer, no glue, no welding. I've been riding the bike for several years since, and it's still fine. When you get a replacement, carefully press it in place. If the fit is snug, leave it alone. It will be fine for a very long time, or maybe even forever, as far as you are concerned.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Cap
        On mime it is the cap that came off, will try the "weild" fix that Steve told me if I can get a used one, as I trashed mine
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • 'OlGuiltyBoy
          • Oct 2011
          • 174
          • Manassas, Va.
          I have both petcocks off of my '80 standard. I'm going to end up buying some pingels anyway. I can sell 'em to ya. PM me
          ~Jay
          Guilty Ones M.C.
          Manassas, Va.
          1980 Standard G
          2001 CBR 929RR
            Maybe someone else can say for sure but pretty sure they done interchange between standards and specials.
              Originally posted by natemoen
              Maybe someone else can say for sure but pretty sure they don't interchange between standards and specials.
              They don't, not even the filters. Two totally different parts....
              • 'OlGuiltyBoy
                • Oct 2011
                • 174
                • Manassas, Va.
                Oh sorry. That sucks.
                ~Jay
                Guilty Ones M.C.
                Manassas, Va.
                1980 Standard G
                2001 CBR 929RR
                  Petcocks from a standard will not fit the Special tank.
                  Marty (in Indianapolis)
                    Yup, was only talking about the filter tower.
                      I may be wrong on this, but I thought the towers were held in be pressing against outside of the tank. I know mine are... The lower lip on the filter tower gets squeezed between the petcock and the tank. Unless the hole for the petcock has been enlarged for some reason, it shouldn't possible for them to fall into the tank...
                        Nope, they can fall out.... BTDT. If you've got a filter that won't stay in the petcock body, try using some 'gas tank repair' epoxy. This will take the fuel exposure.
                        Not a problem on the standards, as those filters are held in with a rivet...
                          Maybe mine is unique then. The size of the petcock hole on my tank is not big enough to allow the tower to fall off. Just installing the petcock holds the tower on. Maybe it's an LH thing, like the brakes? Do the XJ's have the same problem with the towers falling off?
                          • GLoweVA
                            • Jun 2011
                            • 1957
                            • Virginia Beach, VA.
                            Bug, why would Yammy make a different style petcock for the LH compared to the SH?
                            I know the Midnight Special is 'special' and all, but that doesn't make any sense?!?
                            Part number research reveals:
                            3H3-24500-01-00 same part number for the SH and LH, LG and SG and the 82 XJ
                            80G (Green paint(PO idea))
                            The Green Monster
                            Got him in '04.
                            bald tire & borrowing parts
                            Scarlet
                            Got her in '11
                            Ready for the twisties!
                            81H (previously CPMaynard's)
                            Hugo
                            Cold weather ride
                              The tower on my 79 Special has a raised lip that is a recessed fit into the petcock. The hole on my fuel tank is too small to let this lip thru and up into the tank.
