I rebuild my front master cyl. and was very careful to put all the new parts in exactly as I removed the old parts (as the kit comes with no instructions
) I got to thinking and looking at the parts and the spring has a large end and a small end with a flat cover. The master cyl had the small end of the spring pushing againest the plunger and the large end againest the housing
After studying the old parts it looks like the big end should be inside the plunger to center it
Did I assemble it wrong following the PO's mistake or was it correct the way I did it? It is a real pain to get the c-clip in and out, but I don't want to put it back on if it is going to cause problems down the road (it worked fine the way the PO had it but I rebuilt it as a precaution.
I was looking at this (attached) exploded view and it shows U-washer (in addition to the C-clip) that goes between the washer and the dust cover, then a round disk that goes between the plunger and push rod
