Plastic Glues ?
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Plastic Glues ?
    The locking tab has broken off my left side cover and I'm trying to figure out which type/brand of adhesive to get to glue this thing back together.
    Any input you guys have on glues that you've used and how well they work would be great.
    I know there's 'super glue' aka: Cyanoacrylate, and there are epoxies and modeling glues.
    My experiences with super glue is that it really doesn't work for large applications (anything bigger than 3/8").
    I guess it's all about how much surface area there is for the 'glue' to bond to and how much stress it'll be under.
    My microwave door handle, for example, doesn't last too long with superglue.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Gorrilla Glue
    The very tip broke of of mine and I glued it on four years ago with Gorrilla glue. I didn't use any water as I didn't want it to foam up like it does. It is still holding so far If it breaks, I will make a steel bracket and glue / screw it to the cover. 3M makes a two part plastic bumper repair kit but $$. If you have a friend at a bodyshop, they might let you use some of theirs, it would work great IMO
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • CatatonicBug
      • 6117
      • Clinton, UT
      I rebuilt mine with Super glue (the liquid kind) and baking soda. It creates a substance that adheres incredibly well, and is as strong as the original plastic. It's sandable and paintable too. Just slowly drip one drop of glue at a time onto the spot where the piece broke off, then dust it with baking soda. The gule instantly hardens! Repeat over and over until you have a "blob" just larger than the original latch. Use a grinder or file to shape it, and it'll be good as new. I know a couple of other guys have done the same, and no one has had it fail yet.
        That product is from LORD Corporation. The application gun is the expensive part and is used for ALL there products, so only half to buy once. Product comes in a dual tube. The mixing chamber attaches to end and mixes product as it comes out. It is sandable and paintable. Cure time is 1.5min., so have pieces where they wanna fit permanently in short order. Mixing chanbers are a one-time use and about $1.60 apiece The tube of two-part product is $19. Lots of different product choices for different materials. This particular application uses the Fusor143. Product DOES get hot coming out of mixing chamber and if U have to smear it flat a bit it's like getting hot wax on your fingers. Works well and have used it where stress loads are present.
        this product IS avaivable at your local auto-paint supplier.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          3m
          I haven't used that product? Sounds great, the one I was talking about is from 3M and comes in two 16oz tubes to mix as needed (thats why I said to use a dab of a friends if you can) I have only seen it at autobody supply shops and would cost about the same, no gun needed and can be kept and used for many other projects, great for filling scuffed and gashed farrings, car bumpers ect. and any plastic parts
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            +1 on the superglue/baking soda fix. I've used that to repair a couple of sidecovers and had no issues. If the whole tab broke off, 'reinforce' it around the base with some baking soda for a 'stronger than 'new' repair.
            • lee_dutcher
              • Apr 2009
              • 822
              • mason city iowa
              i use a product called plexis
              works grate and have a box full of the stuff...fcan sell some if anybody wants to try..... need an applicator gun or u can cut and mix like bondo thats what i do...
              1980 gs1000g "stock"
              2008 jmstar 150cc Chinese scooter ( wife's bike)
                Yep, did that with mine about 15,000 miles ago and it's still working just fine.
                  • 8062
                  +1 on the body shop. I repaired one with that body shop epoxy a few years ago. It will never break in the same place again! I took it to a body shop. I can't remember if it was cheap or free, but it was one of those. They had the adhesive and they were using it. My job was of little to no consequence.
