Hello to all,
I'm a newbie to the XS11 and motorcycles in general. I raced moto for several years as a kid and had a bike in college, but I haven't messed with a motorcycle in 10 years. I live in AZ and I just bought a 81 XS 1100. The VIN is only 9 digits so I'm having a hard time figuring out the exact model (Title says Model: X1S).
I bought the bike as a roller and paid to have a guy wire it. I also had a local shop get it running and mechanically sound. (I know I should be doing the work on this bike, but I've got enough knowledge to be dangerous - truthfully I'd probably end up catching the thing on fire).
Recent work to get it running:
1. Carb rebuild kit
2. Intake Boot set
3. Slide Diaphrgams
4. 47.5 pilot jets
5. Compression test (130/130/125/145psi)
6. All fluids
7. New Battery
8. Carb sync / tune
I've been riding it around for a couple days and everything seems to work well except for a couple issues. I'm hoping you all can point out and give me some direction. You all are infinitely more knowlegable than I am!
AZ unfortunately requires emissions. I took the bike down and it was hot - 40 minute ride in 90+ temps. I have K&N filter pods and straight pipes 2 into 1 (it's loud and yes, it's awesome).
Test: Idle for 30 seconds and rev to 2400rpm for 30sec and back down to idle. **Please note - I don't have a tach so I was just guessing on rpm (should I have added more throttle?)
Hydrocarbons: 791 out of 1800 = Pass
Carbon Monoxide: 11.25 out of 5.50 = Fail
I used a 91 octane, nothing more.
The data looks like it's running rich? The bike smells like raw fuel even after sitting overnight. Original Pilot Jet is 42.5 (per CLYMER manual). With the K&N filters, modified exhaust and Phoenix altitude (or lack there of) why would the shop select the 47.5 jet?
Am I right/wrong/suggestions?
I already tried to get out of the emissions testing by registering in another county, but that's not going to work. I also read a few posts on adding Methanol to the fuel, but I don't think it will bring the CO down enough to pass. I just want to get the thing plated and ride!
Thanks in advance!
1. Carb rebuild kit
2. Intake Boot set
3. Slide Diaphrgams
4. 47.5 pilot jets
6. All fluids
7. New Battery
8. Carb sync / tune
Thanks in advance!
