Hello. I'm new to the sight and recently bought a 1980 xs1100 mns. I'm looking for a new master cylinder. Does anyone no of a after market master cylinder that would work for my bike? I was interested in one that was on the mikes xs site but when i asked them if it would work for my bike they said they didn't have the schematics on the xs1100. So it may or may not work. Has anyone here used a master cylinder from the mikes xs site or know of another one that would work. Any help would be greatly appreciated thanks.
master cylinder
I think if you look on the bottom of the cylinder there is a size/diameter. You just have to get one either that size or a tad bit smaller ... Don't go too small though because if you tap the brakes you be doing a stoppie and dump your bike~Jay
Guilty Ones M.C.
Manassas, Va.
1980 Standard G
2001 CBR 929RR -
Check out this thread too ... I basically had the same question~Jay
Guilty Ones M.C.
Manassas, Va.
1980 Standard G
2001 CBR 929RRComment
Thanks. I think I'm going to go with the 16mm bore dual disk master cylinder that is on mikes xs site. It's all black and will look good on my mns. I also just installed new ss lines and brake shoes. Hopefully I can get it on the road before the weather in Seattle goes south.-robin
1980 xs1100mns
Ss lines
Mikes xs 16 mm bore master
Superbike barsComment
Thanks. I think I'm going to go with the 16mm bore dual disk master cylinder that is on mikes xs site. It's all black and will look good on my mns. I also just installed new ss lines and brake shoes. Hopefully I can get it on the road before the weather in Seattle goes south.~Jay
Guilty Ones M.C.
Manassas, Va.
1980 Standard G
Thanks. I think I'm going to go with the 16mm bore dual disk master cylinder that is on mikes xs site. It's all black and will look good on my mns. I also just installed new ss lines and brake shoes. Hopefully I can get it on the road before the weather in Seattle goes south.Nathan
Theodore RooseveltComment
Brakes
I used the one from Mikes on my 79 SF, works great with SS lines. That braking system steve refers to gave me the creeps on my 81 LH. I've completely removed it and and went with the smaller rea rMC from a 79 (thanx Andreas) and will use the Mikes 16 mm front MC.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Welcome
Hello. I'm new to the sight and recently bought a 1980 xs1100 mns. I'm looking for a new master cylinder. Does anyone no of a after market master cylinder that would work for my bike? I was interested in one that was on the mikes xs site but when i asked them if it would work for my bike they said they didn't have the schematics on the xs1100. So it may or may not work. Has anyone here used a master cylinder from the mikes xs site or know of another one that would work. Any help would be greatly appreciated thanks.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
fwiw my bike 81R and the 80 standard are fitted
with 5/8 in bores, so theyll also work without
any problems.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
I bought the bike and the p/o had an existing problem of the brakes locking and not relieving pressure. He had also broke off the mirror and broke of a tap in the mirror mount. I bought a rebuild kit and cleaned it out meticulously. It was sparkling but after putting in the rebuild kit I still had the same trouble. I have already taken the mc off twice now with no new results. I will just feel safer knowing the master is new and can mount a new mirror. I want to get it on the road before the season changes. I appreciate the help and I'm sure this won't be my last question.I did end up ordering the 16mm mc from mikesxs and should have it on this weekend. Barring any rain on sunday should get it on the road.
-robin
1980 xs1100mns
Ss lines
Sounds like the spooge hole in the existing M/C has not been cleaned out and is plugged. The Mirror mount is just one enormous PITA too.2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
if u remove the top and look inside there are 2
holes the smallest hole (spooge hole) blocks up and
usually needs a poke with some wire to clear it, that hole
relieves the pressure and returns the fluid back to the
reservior. You could try this til u get ur new 1.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Yup, spooge hole. It is a very small hole specifically for releasing the pressure.Nathan
