Quick Q? about engine speed
  • shovelhead
    • Jul 2011
    • 28
    About what RPM is average in top gear a freeway cruise btwn 60-70 mph (ballpark RPM)
    thanks in advance
    About 5k when flat-land cruising at 70mph, unless you have the XS750/850 Final drive mod which drops that to about 4200.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      And drop that about 500 RPM to start with because of the larger rear tire. With the 750 FD, I turn about 4000 RPM at 75 MPH in 5th gear.
      That's always the problem with absolute answers with these bikes, the true answer is always predicated on which model the answer is based on because of the variances from model and year to year.
        60-70mph........4,000rpm-4,600rpm.......that's on my 81Venturer(Standard)........speedo verified accurate with GPS.
        • shovelhead
          • Jul 2011
          • 28
          well i have a mechanically stock 79 xs1100 std...seems like im running about 6K rpm at around the 70mph mark on the flat land...
            Hmmm....maybe the tach isn't accurate. That seems a bit high. You're in 5th gear? What is indicated at 60 mph?
