Carbs d@#m pos!!
    • 8962
    Sending you a PM...
      Originally posted by XS1100_OEM4ME
      Yes, I put in new fuel needles and seats from my K&L kits, still got gas flowing out the carbs and into the motor, Floats set exact, checked for float leaks, none detected, just gas pouring into the motor and good oil. I am feed up with these carbs and will do what ever to get them to stop pouring gas into my motor
      Make sure that with the bowls off, that you can blow into the vent lines and get air going into the carb bowl area. If the vents are for ANY reason blocked the carbs will overflow, and as long as their blocked nothing else you do will stop them from overflowing. One person had the gas and vent T's swapped, the larger ones go on the bottom, and if you get them swapped they are likely to block the vents and cause the carbs to overflow.
      Just something to check if their overflowing and you can't find anything else wrong.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        Vent lines?
        What do you mean by "vent lines" I have two "run" lines and two "prim" lines, one octy vac line, thats all the "lines" I have to the carbs What are the "vent lines" on a 79xs1100 special
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          • 8962
          On the T's between the carbs, the upper two are bowl vents that go back to the nipples on the airbox. The lower two are the fuel inlets. If you were using the upper T's as fuel inlets, that would for sure cause a flooding condition.
            #35
            Are you certain you have 78-79 carbs? It is not uncommon at all for folks to mix and match carbs with years and models.
            If you have the later carbs, there is only two Ts total between the cabs. The 78-79 models have four Ts total, two lower for fuel, and two upper for vents. Another way to check is to see if there are three or four holes in the inlet bell side of the carbs, the fourth hole was added in the 80 model carbs as a vent, eliminating the need for the upper vent T.
              • 8962
              • Ken Talbot
                • 4251
                • Revelstoke, BC
                #37
                Sounds like you've indentified the problem. The upper "T" between the carbs on '78 and '79 models are atmospheric vents for the float bowls. If you plumb gas into hem, you get flooding.
                Ken Talbot
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  #38
                  confused
                  confused
                  Ok, my carbs have 2 "T's" between the bowl's of #1&#2 and #3&#4 carbs, those hoeses go to the octy then to the "run" setting on the petcock, but have a "t" fitting that goes to the "prim" on the petcock, what is this vents / nnipples
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    • 8962
                    The 2 upper T's run directly to the 2 ports on the airbox, these are your bowl vents. The lower 2 T's run to the octy hoses as in the above diagram.
                      • 8962
                      • petejw
                        • 2269
                        • sydney australia
                        #41
                        hi XS1100_OEM4ME,
                        heres a link to wildkats excellent write up on carbs,
                        on the front page are pics of the late model carbs (sorry i couldnt find
                        any early model pics)
                        if ur carbs dont look like these then u have the early
                        model carbs.
                        and as the others have said, if u have the early model carbs
                        the upper t's need to be either vented to the air or attached
                        to the air box as in phils pic.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          #42
                          Carbs
                          Not sure after reading your post to the year of the carbs, though OEM for 1979 xs1100 special, brass floats, meaning 79 and before carbs, only lines are two "T's" from the bowles feeding the needle valves, they go to the octy and all the prim / T / petcock set up is OEM by the book and all the under seat / clymer / yamaha spec. No upper "T's" going to air filter from carbs No yamaha spec or clymers man or anything else shows that
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                          • petejw
                            • 2269
                            • sydney australia
                            #43
                            can u take a pic of ur carbs?
                            they sound like the early model, but they're
                            all fitted with vent 't's.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                              • 8962
                              Lon, your carbs should have this setup, "A" being the vent and "B" being the fuel inlet. You should have these T's between carbs 1&2 and 3&4. The octy only hooks to "B".
                                #45
                                And A is a vent that hooks to the airbox or at least is open to atmosphere.
