Valve Adjustment
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Valve Adjustment
    I just finished a valve adjustment using the mail order tool #MP 08-0020 I have heard on here that it can't be done. Just wanted to help anyone trying to use this tool to do an adj. 1st, you turn the cam till it is 100% valve open position. 2nd, install the tool in place and turn the cam SLOWLY AWAY FROM TOOL till the tool slips down enough to thread the screw by hand. This will only take a degree or two, then tighten the screw. Turn the cam AWAY FROM THE TOOL at the bottom till the lob is strait up. Remove - replace the shim as needed. 3rd turn the cam back to the tool MAKING SURE you don't hit the tool and BRAKE THE HEAD. Oil the cam lob and turn over a few times, then check with feeler gage. Hopes this helps any trying to use this tool, it is touchy but with some tweeking it works well
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • 9980
    I've been trying to tell them that for years but to no avail. I have absolutely no problem using mine. You just have to feel for the edge of the lifter and have the tool ONLY on that.
    BTW, if you lose the bolt for the tool (like I did), a valve cover bolt works fine.
      Never an issue with mine either!
        • 8766
        Mine works perfect too.
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          Phil, Did you 'modify' yours?? It looks like you ground it down some.
          I don't have one of these YET, but I think I might have to get one.
          When I had my cams out recently, i checked to see what shims I had installed so that way when the time came to replace a few I knew what I got already. Then I looked at the suplement of the manual and realized that the G specs changed and I've only got one valve that needs a shim swap, so for one shim this tool would be easier than pulling out the whole cam.
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
          • petejw
            • 2269
            • sydney australia
            hi george,
            if u are only replacing 1 or 2 shims u dont need to pull the cam,
            if u loosen the cam nuts the cam will rise enough to be able to get
            a shim out. jat
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              • 9980
              Yeah, I think the PO of the okieSPECIAL did that and didn't retorque the nuts right.
              I had a misfire issue and loud top end when I first got it so I pulled the VC and found some of the nuts had fallen off and all of them were loose.
              If you do it that way be certain to get things tightened properly.
                • 8766
                Yes, I had to grind quite a bit off to get it to work properly. I also had to enlarge the bolt holes slightly.
                  • 9980
                  The one I got worked great right out of the box, with some trial and error that is.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    Worker great
                    Mine worked great out of the box also, although I will add, you can't line it up and get the bolt in with the lobe all the way down/open. That is why I said you have to line it up as you rotate the lobe away from the tool a couple of degrees till it drops in place. The lifter is still down far enough for it to hold it down when tightened, to get the shim out
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      Is the motion pro tool the same as the yami one? I didn't hace to alter my yamaha one at all and it works perfect!
                        • 8766
                        Nate, I can't answer that, I've never used the Yami one.
                        • XS1100_OEM4ME
                          • Mar 2009
                          • 1619
                          Copy
                          It is suposed to be an exact copy of the yami tool. It only holds down the valve tapet body (not the shim) at the deck hight, the cam pushes the body well below this level, so if you install the tool just after the cam pushes the tapit body below the deck (far from wide open position) the cam lobe does not keep the tool from being installed correctly, if the cam lobe is to far down, it won't line up right
                          1980 XS1100 Special
                          1990 V Max
                          1982 KZ750 LTD Twin
                          1974 CB750-Four
                          Past/pres Car's
                            Every time I have used it I depress the shim all the way with the cam and then install the tool and then back the cam off. No clearance issues at all, so there must be a slight difference.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              Difference
                              There must be a differance then, that is probably why Phil ground his down. The one I have works fine, but you do have to have the tapit down just below the deck hight or it won't go in
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
